March 29, 2024, 02:23:41 AM *
Author Topic: BIFET Compressor Mic and IC-718 by WA7JHZ  (Read 25687 times)
« on: October 30, 2018, 02:24:25 PM »
The attached JPG shows what I've been doing with my BIFET compressor mic and Icom IC-718. Followed by a decent linear amplifier, it is hard to tell the difference between it and a modified broadcast AM transmitter.
* IC-718 AM Modulator and BIFET Compressor Mic 10-19-2018.jpeg (429 KB, 1820x1140 - viewed 1487 times.)
« Reply #1 on: October 30, 2018, 02:26:18 PM »
The attached JPG shows a reversed order between the 4 kHz LPF and AGC/peak-limiter on my proposed compressor mic circuit. The complex phase shift of the LPF occurs before the AGC/peak-limiter, and its noise and distortion are low enough to allow this. Note that I've also added a positive modulation control circuit (U12).
* BIFET Compressor Mic with no Boost Pos+Neg dynamic 10-30-2018.jpeg (298.18 KB, 1920x1080 - viewed 1421 times.)
ab3al
« Reply #2 on: October 30, 2018, 05:48:00 PM »
does this improve the audio bandwidth of the transmitter or just controll the agressive agc. looking at it from my phone cant see to well
« Reply #3 on: October 31, 2018, 11:07:51 AM »
This circuit is to control modulation levels. There is a 4 kHz lowpass filter to limit higher frequencies.
In general, the only way to improve the audio bandwidth of a transmitter is to modify the transmitter, not with external boxes. Yes, an equalizer can overcome some inadequacies but there are limits to this approach.
Page created in 0.067 seconds with 18 queries.
