April 25, 2024, 07:11:08 PM *
Author Topic: grounding shielded cable  (Read 1999 times)
« on: August 23, 2018, 08:08:50 AM »
been doing a little thinking outside of the box ... a while back the forum was sharing ideas about N2DTS having a hum problem and Brett was adding in some shielded cable to clear out the hum and we discussed how to ground the cable braid :
      the usual practice
      1. audio shielding - ground one end only to prevent ground loop additional hum
      2. rf shielding - ground both ends for maximum shielding
so I propose for your consideration the following :
         --------------------------------------------------------- inner conductor
                        |                                                 | outer shield
                      gnd                                               --|(---gnd
this capacitor between the shield and ground needs to be chosen with the following in mind :
      its value needs have low enough reactance to be an effective bypass at rf and high enough reactance to prevent audio frequency energy from establishing the ground loop ... also be wary of series resonances that could be generated
WA2SQQ
« Reply #1 on: August 23, 2018, 08:27:34 AM »
When I bought my first Flex radio (5000), that used a firewire interface, RF getting into the radio was a big issue. Proper grounding would almost always fix the problem but often RF would get in on one band. Depending on the length of the ground cable, it could be a resonant length. Doing what you proposed was standard practice for Flex 5000 owners for the grounding cable. I used some old RG-8 coax and added the capacitor. In doing so you provided both a DC ground and an effective RF ground.
VE3ELQ
« Reply #2 on: August 23, 2018, 01:16:50 PM »
My earlier transmitter designs used UN-balanced audio inputs and were prone to hum and RFI. Grounding one end solved the hum issue but not the RFI so tried a .001 mfd cap at the TX end as suggested and that eliminated most of the RFI so it will work OK. Finally smartened up and went to fully shielded balanced audio inputs (3 conductors) grounded at both ends and that cured it completely. The input audio amp is a little more complex but worth it.
73s  Nigel
A "Tube Free" zone.
MikeKE0ZUinkcmo
« Reply #3 on: August 27, 2018, 01:13:08 AM »
I recently went through my station fixing all the years old AC hum problems.   I used probably fifteen 600 Ohm 1:1 transformers, in addition to some work on a couple of linear amps with AC issues.   Now the audio is much better.       If you are concerned about audio runs, the first thing you should consider is converting to balanced feeds.
Here are some various balanced and unbalanced grounding configurations, note the labels at the very top of the columns.
Mike KE0ZU
