April 23, 2024, 08:41:34 PM *
Author Topic: Inovonics 222 Wiring a D-104 to a Super Senior TX Question  (Read 2530 times)
W6TOM
« on: June 05, 2018, 06:15:52 PM »
   I posted awhile back asking what might be a good peak limiter to use with my 80/40 Super Senior to avoid over modulation lockouts, the Inovonics 222 was one of the suggestions. I found one at a swap last weekend, now to wire it and do the adjustments.
    I have a D-104 with the K7DYY audio board and a 6 foot long microphone cord. The Inovonics 222 has a balanced input and output, op amps from the schematic.
    So what would be the best way to wire the D-104 to the input and also wire the output into the Super Senior?? Any suggestions on how I should set up the Inovonics 222?? Thanks!!!
« Reply #1 on: June 05, 2018, 06:39:11 PM »
without looking at a  222 manual, I think it works at line level, maybe selectable with jumpers, etc .... line level is roughly 2V pp into a 600 ohm load corresponding to 0 vu .... if you do not have a line level input on your tx then you should pad it down to avoid overdriving the mic preamp stages .... simplest way is a pot of any value from 600 ohm to meg ohms ....send the wiper to the mic audio tx connection .... maybe the d104/preamp will generate the 2Vpp needed, if not you will need some gain stage(s) ... scope time
KQ6F
« Reply #2 on: June 05, 2018, 07:27:52 PM »
I have same setup - Inovonics 222 into Super Sr.
Connect your amplified D-104 output to Input + and Gnd on 222.
Connect 222 Output + and Gnd to pin 2 and pin1, respectively on Super Sr front panel connector.
W6TOM
« Reply #3 on: June 08, 2018, 06:00:50 PM »
 Inputs are + _ and there are two common grounds, audio to + and _ or use common ground for audio ground?? Thanks....
KQ6F
« Reply #4 on: June 08, 2018, 08:32:52 PM »
GNDs are both the same - doesn't matter.
Page created in 0.086 seconds with 18 queries.
