April 16, 2024, 01:45:04 PM *
Author Topic: HV Power supply question.....  (Read 32745 times)
kc2ifr
« on: March 30, 2005, 04:44:17 PM »
Was wondering which would be better for a plate supply for a high power linyer for AM. Choke inpoot or no choke.....just caps. If choke inpoot, should the choke be a swinging choke or fixed.
TNX in advance,
Bill
« Reply #1 on: March 30, 2005, 06:25:28 PM »
Quote from: kc2ifr
TNX in advance,
Bill
Hi Bill,
Most of the commercial linears today do not use  chokes in their HV supplies. Better quality older ones like Henry usually did.  The choke helps with better regulation, but it also helps to reduce hum.
I notice that most commercial amplifiers have hum on the carrier when they are tuned up on the air. You can get only so much filtering with a big bank of capacitors.  On my big amp I have about 100 ufd, but when I short the choke out I can see a little hum on the scope.
Bottom line is get a swinging choke if you can, but a standard choke will work FB if you have some decent capacitance to work with.  Hopefully your capacitor values will be the limiting factor for regulation, not a transformer that is too small to keep them charged under a heavy load.
What tube are you using  for the linear?  Is that for the 4CX-1500 ?
Tom, K1JJ
W2JBL
« Reply #2 on: March 31, 2005, 12:32:19 AM »
i like choke input, and also use a bleeder that sucks down 100-150 mils. the common HV supply that runs one of my stations uses a 20 henry choke and 50MFD of cap with heavy bleeder. the output is rock steady from 100 to 800 mils current drain. voltage doubler supplies with cap only for filtering never seem to work well for me. i have also found you can get away with poor regulation on a linear running AM where on  SSB your signal goes to hell in a handbasket with bad regulation.
« Reply #3 on: March 31, 2005, 12:41:06 AM »
The choke supply will yield better static and dynamic regulation. Get more info on power supplies at the links below. But, if you have enough capacitance in a cap input supply, it will be stiff enough for the plate supply on most linear amp designs.
Power Supply Design and Dynamic Regulation, PDF 1, PDF 2, from the GE Ham Tips supplied TNX to  John, K5PRO
The Henry amps use a resonated choke input filter. A cap is placed across the choke to resonate it at 120 Hz. The two form a series resonant circuit thus presenting a high impedance to the ripple voltage from the rectifiers.
Many consider this design superior because it reduces the amount of inductance and capacitance needed in an LC filter to reduce the ripple to an acceptable level. For production this means lower cost for the components and less space needed to house them (the cap and choke will be physically smaller), so a smaller less expensive enclosure can be used. These are valuable to a homebrewer too.
This arrangement also requires less bleeder current to prevent voltage from soaring under no load/small load conditions. So you can use a higher resistance bleeder that will dissipate less power, thus a smaller, less expensive resistor. And your supply will be cooler because you are sucking less current out of it just for bleeder. The extra current can now be used to power the amp (more efficient use of the supply).
On the other hand, some people think resonated choke filters are more bother than they are worth since the choke/cap combo must be selected/tuned to really work well. And their dynamic regulation may not be sufficient for quickly varying loads (e.g. linear amp). But they seem to work FB in the Henry amps, so who knows.
So, if you already have a pretty big choke >= 10 uH, messing with a resonated design might not be worth your while. Getting large amounts of capacitance at HV is pretty easy and cheap these days, so following a good choke with a bunch of capacitance will make for a good stiff supply.
Steve W8TOW
« Reply #4 on: March 31, 2005, 08:24:56 AM »
Building a amp for SSB, ideally, a swinging choke as the input choke does best. Since obviously, as your current demand increases so wil the regulation.
Another thought, is to go with a Collins idea of using a resonant circuit...
Thus a cap & choke in parallel (I think they were chosen to have a resonant freq of 120 HZ ) then a really big cap afterwards....
gl es 73 steve
73  W8TOW
« Reply #5 on: March 31, 2005, 08:46:52 AM »
It will depend on your high voltage transformer and the output voltage you need. A choke input filter will give you less voltage but better regulation. Second choice would be a cap input filter with a choke.
This way you get less ripple with higher voltage out.
My old 4-1000A linear used a pair of BC610 transformers. Choke input in the stock form only did 2500 volts out. I used a cap bank and got 3300.
2500 volts on a 4X1 is pretty useless so I needed more voltage.
Roy K8VWX
Pr. 4 -1000s Mod Pr. 5868
« Reply #6 on: April 01, 2005, 02:03:03 PM »
Have always used resonant ( tuned  ) chokes in linears . Really the way to go as Art Collins found out. Use one in my 3CX3000 F7 running 5000 volts on the anode (plate) and only drops around 300 volts @ 1.5 amps :badgrin:  :p .On the dummy load of course. Also have a tuned choke in the HB 5868 class B modulator with excellent regulation.
« Reply #7 on: April 01, 2005, 02:40:36 PM »
4700 volts 1.5 amps for 1500 watts out........that is quite a message!
« Reply #8 on: April 01, 2005, 03:02:16 PM »
That's... 1500 BIRD WATTS... caw moan !!!!!
« Reply #9 on: April 01, 2005, 03:06:28 PM »
now that is flappin your wings bird watts!
Roy K8VWX
« Reply #10 on: April 01, 2005, 10:20:31 PM »
My Avatar is a pair of 4-1000s modulated with a pair of 5868 in class B. The 3CX3000 F7 is a LINEAR for SSB and it will loaf at the leagal PEP ( it isn't restricted to what us AM folks are 1500 PEP ). Some day I will change my avatar to the HB GG / 3CX3000. It is pretty  Cheesy
kc2ifr
« Reply #11 on: April 04, 2005, 07:36:25 AM »
TNX for the replies guys.
Tom, the screen supply for my 4CX1500B linyer bit the dust and I am rebuilding it. While I was pondering a new design...the old one sucked....I got thinking about general HV supply design. Although the new screen supply will use these boards http://www.ifwtech.co.uk/g3sek/boards/tetrode/tetrode-1.htm and the choke question really doesnt apply to them......I was thinking about adding another 4cx1500b to the amp. If I do, Ill have to beef up the HV supply. As of now it will provide 3KV at 1amp and uses a Peter Dahl swinging choke input supply. Another tube would require a supply capable of at least 3KV at 2amps or better and ofcourse new iron. But after thinking about the whole idea......I decided to just rebuild the screen supply and leave well enough alone. Maybe in the future Ill build something different and need a bigger HV supply. Depending on who you talk to about choke input supplys, you get different opinions. I like swinging chokes because I always thought you get better HV regulation. Cap input supplys will give more voltage for a given transformer but less regulation I was told.
Anyway thanks again for all the replys. And Steve, I printed out the pages u listed....very good stuff....thanks.
Bill
« Reply #12 on: April 04, 2005, 08:00:47 AM »
Oh yeah?  Last I checked 1500WPEP was the limit for ANY mode.
A Fine Business amp, Roy!
73 John
« Reply #13 on: April 04, 2005, 08:26:17 AM »
Hi Bill, Pay close attention to the transformer Voltages called out for that screen supply. There is no room for error. Give yourself plenty of time to build it also. It takes time to figure out the destructions. You can still have a plate to screen zorch even with the board's protection. Stuff can still get cooked. Ask me how I know this. %$#%&*%#! Also let any new 4CX1500B's play with filament Voltage only for at least 24 hours and hopefully the filament will getter any gas.
Step 47: build a triode amplifier. Step 48: retest blood pressure.
The best part about swinging choke input supplies is that the B+ won't go much higher than your full load Voltage. The higher Voltage will invite parasitics and internal tube flashovers. Some say the transient regulation of a choke input supply is poor. Same guys don't quote filter capacitance values. Same guys build hamateur amps and have to cut cost. With cheap modern small capacitors it is easy to come up with values many times larger than what was seen in a buzzard's prime. Some type of step start should be added when using a heap of filter cap. Also becomes much more dangerous. I'm sure you know this stuff but is makes for good discussion.
It would be good to see the math Roy uses to resonate filter chokes. A great way to get more of existing iron. There was an old QST article that showed how to figure actual inductance of a power supply choke with DC current flowing through it.
kc2ifr
« Reply #14 on: April 04, 2005, 08:52:59 AM »
Dave,
Im not sure why the screen supply pooped the bed. I replaced the toob with a "new old stock" toob that had never been used. I burned it in for about 18 hours with filaments and blower only although 24 hours probably would have been better. The amp was working fine for about a week or so. One day I fired it up....let it warm up for about 5 minutes before applying HV....applied HV and all was fine. In use, the HV is applied all the time.....the toob is cut off during receive. When I applied drive...the HV overload kicked out. Reset the HV and tried again. This time the HV held but little or no outpoot then I smelled the smoke! Shut her down quickly. Pulled out the screen/bias supply chassis and found all the screen zeners shorted causing the screen droping resistor to get REAL hot!! Basically the whole screen supply fried. Checked the screen ckt in the amp for shorts but found none. SOOOOOO......I think the toob flashed but not sure. There was no protection at all in the screen supply....not even a fuse in the primary and no flashover protection.
Anyway...I hope the new supply Im building will solve any more problems. I just hope the toob is still good.
Bill
« Reply #15 on: April 04, 2005, 09:15:40 AM »
That tube flashed like Chester the Molester. That was a good working amp too. Well, you will get it back on line soon enough. Meantime maybe take some L and C out of your 4-1000.
« Reply #16 on: April 04, 2005, 09:30:07 AM »
Bill,
Make sure you use a load resistor on the screen at the tube. I think the screen can swing negative current in the 4CX1000 / 1500. This way if you blow a fuse the screen is pulled to ground with the load resistror.
I don't remember where I read this but years ago I was going to build a 4CX1500 amp before I landed the box of 4CX3000As
It might have been Eimac care and feeding of power grid pube book.
The screens can't handle much power so don't build a big supply.
Don't store a lot of energy in the screen filter.  It may have been VHF oscillation that flashed it over.  fc
wavebourn
« Reply #17 on: April 04, 2005, 11:49:47 AM »
What about using FETs?
« Reply #18 on: April 04, 2005, 11:57:52 AM »
That is a good point, Tolly... use a FET as a pass regulator fer the screen.  Or you could use a cheapo horizontal outpoot transistor.  I did this years ago to replace the pair of stupid 6082 triodes in a R-390.
You need to reconize and deal with the potential for negative screen current though.
73 John
« Reply #19 on: April 04, 2005, 12:04:39 PM »
Here's the goods if you want an efficient 2KV or less screen regulator
for big tetrodes. I once had use of this circuit before going to all
triodes. From Richard Measure's site -
Tom, K1JJ
« Reply #20 on: April 04, 2005, 12:14:46 PM »
This circuit needs a supply with at least 15 volts of ripple to peak charge the boot strap. Also needs a load resistor to handle reverse screen currents.
« Reply #21 on: April 04, 2005, 12:29:44 PM »
And lose that friggin LM723.  Use an LM350 three-legged variable regulator instead - just make sure you use plenty heap big RF bypass on it or it'll sing like Ethel Merman.
« Reply #22 on: April 04, 2005, 12:35:54 PM »
Still need to address the reason the original screen circuit popped. Tubes will be tubes.
Paul, K2ORC
« Reply #23 on: April 04, 2005, 01:06:14 PM »
Quote from: w3jn
Perhaps a stupid question, but how come lose the LM723 in favor of an LM350?   Durability? Stability?  I think maybe I was sleeping in class when something about the LM723 came up on the board before.
Go Duke![/b]
« Reply #24 on: April 04, 2005, 01:08:10 PM »
Paul - parts count, durability, power handling, simplicity.  The 723 is the one to use if you really need precision, though.  A screen voltage regulator is NOT one of those cases.
73 John
