April 20, 2024, 08:47:01 AM *
Author Topic: Top Hat for 40M vertical  (Read 2146 times)
WA2SQQ
« on: April 02, 2018, 02:40:49 PM »
I started building a 40M vertical and I’d like to add a capacitive top hat. My understanding is that it can broaden the bandwidth.  Just wondering how large it needs to be, is bigger better?
PA0NVD
« Reply #1 on: April 02, 2018, 04:56:53 PM »
A top head doesn't broaden the bandwidth,. If you have to shorten the antenna and make it to resonate, a top head gives you a wider bandwidth and a higher radiation resistance COMPARED to a loading coil, so it is preferred. But the bandwidth of a shortened antenna will always be narrower than a full size.
I advice downloading MMANA, an antenna simulation program, works very fine, fun and is simple to use. I posted a 40 and 20 meter vertical in antennas
« Reply #2 on: April 02, 2018, 09:14:14 PM »
You would only need a top hat if your vertical is not a quarter-wave length (about 33 or 34 feet). If you want more bandwidth, use a larger (fatter) vertical element. This can be a larger size tubing or the use of multiple wires in a cage configuration.
WA4WAX
« Reply #3 on: April 03, 2018, 11:46:35 AM »
Whatever you do, put the hat on the very top of the antenna.  Do NOT put it on the top of the loading coil if you are using a loading coil as well.
Try an 8 to 10 inch hoop with varying numbers of spokes.
Matt
WA2SQQ
« Reply #4 on: April 04, 2018, 10:36:38 AM »
Thanks for the clarification. The radiator will be made from the aluminum tower legs from my tower than came down 6 years ago. They are about 1 1/4" in diameter so that alone may give me some extra bandwidth.
