February 18, 2026, 11:19:49 PM *
Author Topic: EL7144C second source  (Read 8575 times)
W4AMV
« on: March 26, 2018, 01:55:14 PM »
The EL7144C was used as a MOSFET driver in Class D PA's. It is a Schmidt trigger limiter. I am looking for a supplier or a current second source equivalent. Thanks for any information. 73' Alan
M0VRF
« Reply #1 on: May 01, 2018, 09:36:54 AM »
Does it have to have the same pinout?
If 'NO' then use the now 'famous'? NCP81074.
J.
W4AMV
« Reply #2 on: May 01, 2018, 10:52:23 AM »
Thanks, I'll check it out! Alan
W4AMV
« Reply #3 on: May 02, 2018, 11:18:40 AM »
This device looks like it would fit the bill. Although it is specified with a pulse input drive. I assume I either pre shape a sine wave input or slightly overdrive. Does the device function well with sine input? Thanks, Alan
« Reply #4 on: May 13, 2018, 08:56:11 AM »
Hmm. I took a look at the ratings.  Has anyone used these to drive a fairly big MOSFET such as an FQA11N90 with 2700pF of input capacitance?
Just curious.  The max steady-state current is fairly low and the internal resistance is not all that low.  Might work into a single device on 80 meters.  Not so sure about 40 meters, where the input impedance of the MOSFET would be in the order of 7 ohms.  Maybe.  Has anyone tried this?
Interesting !!
Regards,  Steve
