April 19, 2024, 07:49:06 PM *
Author Topic: 6CW4 vs 6DS4  (Read 3742 times)
WA2SQQ
« on: February 20, 2018, 05:52:17 PM »
Doing a small restoration project on a receiver that uses 2 6CW4s. One tests marginal. I have a new 6DS4 which I’m told is interchangeable. Anyone know the difference?
WD4DMZ
« Reply #1 on: February 20, 2018, 06:12:25 PM »
According to this list the answer is yes:
http://www.nostalgickitscentral.com/info/tubexref6.html
Scroll down to the 6CW4.
Rich
w8khk
« Reply #2 on: February 20, 2018, 06:34:17 PM »
According to the RCA receiving tube manual RC-24, the 6CW4 has slightly larger transconductance 9800 umhos compared to the 6DS4 with 9000 umhos.  The plate resistance of the former is slightly smaller, 6600 ohms, compared to the latter 7000 ohms.  Thus the characteristic curves are slightly dis-similar.
The manual also states that the 6DS4 is used in circuits to reduce cross-modulation because of its cutoff characteristics.  All other ratings are identical, so it should work fine as a direct replacement for the 6CW4.
