FS- 1 AEROVOX HV CAP 13MFD 1600 VOLTS TYPE-SX13M29 (SEE CAUTION NOTICE)
January 24, 2019, 04:25:46 AM *
Author Topic: FS- 1 AEROVOX HV CAP 13MFD 1600 VOLTS TYPE-SX13M29 (SEE CAUTION NOTICE)  (Read 463 times)
k4rhh
« on: February 13, 2018, 10:24:21 PM »
THIS IS FOR 1- NICE OLD HIGH VOLTAGE CAPACITOR BY AEROVOX TYPE -SX13M29  13 MFD 1600 VOLT.(NOW CAUTION).THIS CAP IS DIFFERENT FROM MOST. THE CASE IS GROUND NEG FOR THIS CAP AND THE 2 SCREW POST ON TOP ARE TO HOOK UP FOR THE HV + POSITIVE EITHER POST. THESE 2 POST ARE TIED TOGETHER ON THE INSIDE. THESE WERE IN A MULTI SERIES PACK ARRANGEMENT WERE +VOL CAME IN TO ONE POST AND OUT THE OTHER POST TO THE NEXT CAP.AND THE GROUND IS TO THE CASE HAS A TAB AT THE BOTTOM W/ 2 HOLES TO HOOK UP THE GROUND WIRE, SO YOU NEED TO BE AWARE OF THIS CAUSE IF THIS CHARGED UP AND HOLDING IN ONE HAND AND TOUCH EITHER POST YOU GONA GET ZAPPED.SO BE WARNED AS THERE IS NO WARNING ON THE CASE.. I HAVE 4 OF THESE. $10 EACH PLUS SHIPPING. EACH WEIGHTS 4.5LBS  RANDY K4RHH  rwcradiocollector@gmail.com
 AMfone 2001-2015
