New home-brew 40 meter RF deck
December 15, 2018, 06:48:14 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: New home-brew 40 meter RF deck  (Read 8885 times)
"Let's go sailing, Tommy!" - Yaz
« Reply #25 on: February 10, 2018, 10:11:19 PM »
I would say we are in agreement on all points, Rick.
BTW, you make a good point about the choke having less stress when in the series-fed  (push-pull) configuration.  I can see how that would be the case.  All of my pi-wound explosions have occurred using standard pi-network rigs.   Though, there may be a time when Ron makes a mistake and things get unbalanced, a tube shorts, the rig takes off with a parasitic, etc. The single layer choke would have a better sense of humor when kicked in the BAs... :-)
“Remember, remember, this is now, and now, and now. Live it, feel it, cling to it. I want to become acutely aware of all I’ve taken for granted.”  -  Sylvia Plath
Favorite Song - Trololo thru the years:
https://www.youtube.com/watch?v=IVqUecYGnoM
W8ACR
Penta 254W
« Reply #26 on: February 10, 2018, 10:16:43 PM »
So here's the outcome of the smoke test. It actually seems to work! At 1500V and 200mA, I get 210 or so watts out according to my Drake W4 meter. So that is about 70% efficiency which I think is OK for an old buzzard push pull circuit. I was going to run it at 250mA, but the plates glow pretty bright even at 200mA, so I don't want to push them too hard. The data sheet on the HK54 says that the plate should be a dull red at full output. I would say that this is more like a medium orange (see pics). Anyway, it's pretty, and it seems to be doing what it's supposed to do. I did load it up to 1600V@250mA and got about 250 watts output, but the plates looked pretty hot, so I backed off to 1500V and 200mA. That should be enough power for most casual AM operating.
Tom, I get a nice dip at resonance, so I think the plate choke is probably adequate.
Now I need a few spare HK-54's or TG-35's which are basically equivalent. Anybody got a few spares?
The first pic below shows the meter readings at rest. It also shows the position of the RF deck in the cabinet. A 20 meter RF deck goes just above the new 40 meter deck. The 20 meter deck has push pull 254W's and is capable of 500W carrier output. It was my first push pull project and isn't so pretty, but it works great!
The second pic shows the tube filaments glowing at rest, and the last pic shows the plates glowing red/orange at 300W input
I'm happy tonight.  Smiley
73, Ron
The AM voice of Knox, North Dakota
« Reply #27 on: February 10, 2018, 10:27:47 PM »
What a thrill, huh?  Especially when it works right away like that. Congrats, OM.
Will it be plate modulated using a common plate modulator for all the RF decks?  Plan on some audio negative FB?
Did the RF deck neutralize without much trouble?
W8ACR
Penta 254W
« Reply #28 on: February 11, 2018, 03:32:47 PM »
Yes Tom, quite a thrill to use a transmitter on the air that is truly unique to your station. I wish I understood modern electronic technology better, I'd build something a bit more up to date, but I also like the nostalgia of using a transmitter from the 1930's or 40's.
The new RF deck neutralized quite easily.
I have one modulator for the various RF decks, it uses 811A's driven by a pair of 6A3's. I use a modulation reactor and a UTC S-22 mod transformer. The driver transformer is a UTC S-9. The speech amp uses a 6SJ7 followed by a 6N7 phase inverter which drives the 6A3's. There is no negative feedback. All the audio is home-brew except that I power the speech amp with a 0-300VDC Lambda regulated power supply. Lots of old glass envelope 6L6's in that power supply, four or five I think. The 811A's run at  ~1300VDC and have -2.4 volts of bias. Idling current is about 40mA. The 6A3's use cathode bias. I use a Heil classic mic through a W2IHY mic amp. Nothing fancy at all, but I get good reports.
My third RF deck is a 160-80-40 meter deal with an old Taylor 822 triode in the final position. It has a pi network tank with grid neutralization and works FB. I can put two RF decks into the cabinet at any given time, and it just takes a few minutes to switch the necessary cables from one to the other. As you can tell, I like triodes. I don't know if K9ACT is still around, but he once said "triodes are nice", and I agree.
Murphy paid a visit to my shack last night. I was testing the new RF deck into a dummy load, and I wanted to recheck the neutralization one last time. I tuned up the RF deck so that it was tuned to resonance, and then I disconnected the B+ cable from the back of the chassis (B+ is off of course). I did this from the front of the cabinet by reaching through, and after the cable was disconnected, I let it drop so that it would just dangle. I turned away but then heard a "pop". The circuit breaker at the house breaker box also snapped off. This was not a loud crack or sizzle, and there was no smoke or smell. I immediately thought that the B+ cable had hit against something that had caused a short of some kind, but when I went behind the cabinet to investigate, I could not see anything that it would have hit, and I saw no damage of any kind. All the various decks of the transmitter are fused, but none of those fuses blew. I reset the breaker and turned on the power to the RF deck, and only one of the final tubes was lit. I jiggled it around in it's socket, but no joy. Being an Eagle Scout, I was prepared. I just happen to have a couple of spare HK54's. So i get one, plug it in, let it warm up a bit, and hit it with about 500V on the plates. Man, you've never seen such wild blue and purple colors. It looked like an 866/3B28 cross. LOTS of gas in that tube! OK, so I grab another one, and plug it in. This time it looks OK, but when I apply RF drive, the plate goes to white hot (exaggeration) quickly while the other plate has no color at all. I check grid bias voltages, all OK. I switch the tubes in their respective sockets, and the same tube goes nuclear while the other tube does nothing. I get my last spare, and the same thing happens. The original tube does nothing, while the "new" spare gets hot very quickly. OK, one last combination to try. I take out the original tube, and put the two spares into the sockets. This time it seems to tune up normally again.
I'm still not sure what happened, but the end result was one dead tube from a broken filament, and one tube that lights up OK, but apparently does not conduct. The icing on the cake was that one of my spares is also no good from gas in the envelope, sure looks cool though. More testing today.
« Reply #29 on: February 11, 2018, 08:43:37 PM »
Ron -
That sounds like a "catastrophic crap-out."  You probably have it fixed by now.
That's the problem with old tubes - the gas.  I have a batch of about (20)  25-G old power tubes. Maybe four were good and the rest arced over.  The seals are good for just so long.
So you're an Eagle Scout! Fantastic.  Many people have no idea how hard it is to become an Eagle and what it says about the young man who attains it. I would hire an Eagle Scout in a heartbeat.  I am a Life Scout... have 27 merit badges and was ready for the Eagle board of review. Sad to say that I was 13 at the time and the troop committee thought I had advanced too fast and insisted I wait. Ham Radio came along and that was it for scouting.   I should have told that committee to F themselves and finished. [sigh]
I'll bet there are some more Eagle Scouts on this BB.
W8ACR
Penta 254W
« Reply #30 on: February 11, 2018, 10:02:29 PM »
Yeah, I slipped in under the wire. I got my eagle scout on December 20, 1975 and turned 18 on Jan 7, 1976. Ham radio almost derailed me too. I got my novice license in August 1975, and spent a lot of time on the radio that fall. My middle son also got his eagle a few years ago. He and I are a lot alike, but I can't get any of the boys to get interested in ham radio. Computers are where it's at these days. Boy Scouts was a big part of my teenage years. I went to Philmont scout ranch at age 16, and that sealed the deal for me. I was definitely going to live in the American West. I grew up in Ohio, but once I visited New Mexico, I knew I would not stay in Ohio for long. Since 1997, I have either lived in North Dakota or Montana. I have a cabin in Montana out in the middle of nowhere, and once I am retired, that is where I'm headed.
The 40 Meter RF deck is now working adequately, but I can't seem to get it to work as efficiently as the handbooks say I should. According to the handbooks, a single HK-54 should be capable of 200 watts output with 250 watts input. I have two of them in push pull, and at 300 watts input, I get about 200 watts output which is right at rated plate dissipation. The numbers I get from my meters look good however, and the waveforms on the O'scope look good, so I'm not gonna complain. I did try to put it on the air tonight, but no response to my CQ. Will keep trying.
Here are some pics of the transmitter after I added the new RF deck. The top deck is the 20 meter 254W push pull RF deck. The next panel is just a plexiglas window, and then the new 40 meter RF deck is just below the window. Below that is the meter deck, followed by the Bias deck and the control deck. To the right are the audio decks and the power supply decks. As you can see, I added an "RCA" logo to the new RF deck. Don't know why........I had one and thought it might look nice. Wink
« Reply #31 on: February 12, 2018, 10:49:05 AM »
....   I should have told that committee to F themselves and finished. [sigh] .....
Can you get a merit badge for that ??  Huh
« Reply #32 on: February 12, 2018, 11:55:06 AM »
OK Ron -
An 17 year old Eagle is a dedicated one... :-)
For more power out:
When fine tuning the rig for max output, I usually play around with the inductance/ Q ratio just to be sure it is reasonably close to the desired plans. There is usually a sweet spot where you can squeeze out a few more watts, despite careful design calculations beforehand.
Be sure the high voltage is at maximum or something that can support the desire for more wattage. I've found that getting near the max rated voltage is best overall.
Be sure nothing is getting warm, like the coils, chokes, etc.   Swap the tubes around to be sure they are good.
Use a lot of bias and keep drive / grid current up to maximum or slightly higher than rated. I've found maximum drive is best for max audio peaks too.
I've rarely built a rig that puts out full power until I do some diddling around, especially with a more complex rig - unlike a simpler linear amplifier.
Make sure the grid  bias is not creeping up excessively over time.   RF rectifying into the fixed bias filter capacitor can do this.  (if you use a combo of fixed bias / grid leak, that is)
Be sure your power measurement is accurate and can be verified by measuring the RF voltage across a 50 ohm non-inductive resistor.
Check the filament voltage under full rig power. Be sure the AC  120/240 input is not sagging to affect the fil xfmr.
But in summary, my guess is if you experiment / tap the coil in a few different spots, you may find a better transfer match and more output power.
There's more, but run with this for now....
W8ACR
Penta 254W
« Reply #33 on: February 12, 2018, 12:08:28 PM »
OK Tom,
Lots of good suggestions. Will play around with various settings and see what I come up with.
Ron
« Reply #34 on: February 12, 2018, 02:22:28 PM »
Ron,
   Another concept from fellow member Giorgio in3iex is shown here:
http://amfone.net/Amforum/index.php?topic=29030.0
    This could be as simple as adding a cap across some of the output coil turns on each side which are tuned to the third harmonic. That should get you to 90% efficiency.  Tongue
« Reply #35 on: February 12, 2018, 03:12:28 PM »
Very interesting, Jim.
Most comments in that post said there was a big improvement except one.  Bill/HG  said it gave just 2-3% more eff but then his rig was already driven very hard.  This shows the value of driving a conventional class C grid hard even if there is no 3rd harmonic resonator.  I run my 4-1000A grids at about 50 mA each - about 10 mA higher than recommended and get great eff, high audio peaks, etc.
Bill said:
"Years ago, I tried that 3rd harmonic trick on my 304-TL rig.
Driving the snot out of the tube in a conventional pi-net gave me around 85% measured efficiency, the 3rd harmonic trap added, at best, two or three percent.
The thing is, when you drive a triode hard, the plate waveform does approach a square wave, being switched hard between "on" and "off".
I suspect this 3rd harmonic wave shaping scheme works the best when drive to the Class C stage is fairly low."
W8ACR
Penta 254W
« Reply #36 on: February 12, 2018, 04:05:48 PM »
OK, so the tube data sheet says that maximum grid current is 30mA, and a typical value in plate modulated service is 20mA. I've been driving the two tubes at 40-45mA. How high do you think I can safely go without putting the tubes into danger of failure?
I've got lots of leeway in the grid voltage department. I think the maximum grid voltage is -600, I've been using -250 to -300.
I've got plenty of grid drive capability, up to 150 watts or so, and I can vary the grid leak from 0-10K ohms
Ron
« Reply #37 on: February 12, 2018, 05:29:17 PM »
Ron,
I have zero experience using HK-54s, but based on other homebrew class C tube rig experience, I would start experimenting with parameters.
Try increasing the grid current / drive to the maximum rating and then even go past it a little to see if it makes an improvement. At the same time vary the grid leak resistor settings, drive power and change the loading and tank Q.  Take careful in and out power measurements and you will find the sweet spots for max power out and eff.  Later, do the same thing using an audio sine wave and see how high the modulation audio peaks will go cleanly.  (careful with mod xfmr)
See if there is a saturation point when it comes to grid current and drive. You are already near the grid ratings.  Many of my rigs will keep modulating higher and higher % as I increase grid current and then reach diminishing returns. The best spot is to get everything within tube ratings, though the grid sometimes needs slightly more than recommended current. At least this is the case with my 813 and 4-1000A tetrode rigs. I understand that triodes have a bigger appetite for grid current performance.
I looked at the HK-54 specs and see the max voltage as 2KV in plate mod service.  Maybe you can increase your voltage to 1800V if the mod iron can take it.
It is amazing how high the efficiency can get when a tube is driven very hard with heavy bias, almost approaching class D.  Maximum HV and you have a real man's rig.. :-)
You already know to be careful and methodical so not to blow out a tube or mod transformer when testing.
I'd say you are probably already close to a good operating rig which simply needs adjustments.
« Reply #38 on: February 12, 2018, 06:08:25 PM »
The 3rd harmonic filter is fairly well known, even being mentioned by Eimac in the 3-500Z datasheet (the one which has the switching / pwm data on it).
I've heard it called taloe and Taylor circuits.
Also called class F.
W8ACR
Penta 254W
« Reply #39 on: February 14, 2018, 08:39:45 PM »
Success! I made my first contact tonight on 7285 KHz using my new RF deck. North Dakota to Ohio. Got a good report. I ended up running the RF deck at 1700VDC@150 mA for 255 Watts input and about 200 watts output. Will probably push it a little harder next time, but very gratifying to get that first QSO under my belt.
KA7WOC
« Reply #40 on: February 14, 2018, 09:40:14 PM »
Congrats
I rooted around the shack and found some tubes.  I don't know if they are good or not.  I will get them shipped out soon (next week) and you can test them.  2@HK54 and 2@Fisher 822
Bob ka7woc
Bob (aka Boatyard)
W8ACR
Penta 254W
« Reply #41 on: February 14, 2018, 10:37:41 PM »
OK Bob,  Thanks, Hopefully we can get a SKED set up soon.
Thanks again, Ron
« Reply #42 on: February 14, 2018, 11:49:26 PM »
Ron,
78% efficiency is quite acceptable.
So what did you do besides raise the plate voltage to 1700V ?   How hard are you driving the grids now?
You will probably find that the rig runs the cleanest audio when the final is loaded heavily, but then the power output is reduced as the tradeoff.   It's now a matter of tweaking the parameters.   Those old triodes should be good for 84% eff if driven real hard. You're almost there.
W8ACR
Penta 254W
« Reply #43 on: February 15, 2018, 12:01:46 AM »
Hi Tom,
Well, The grid current was 45 mA and the grid voltage was about -280. I just played around with the different parameters and this is what I came up with as far as keeping the plate dissipation within acceptable limits. The plates of the tubes were still a dull orange, but I believe that I was within acceptable limits. After my QSO I loaded it up to 200mA and I think I'm still OK, so I'll try that setting tomorrow. Anyway, I know that it works, and that it sounds OK on the air. I'm happy again tonight.  Smiley 73, Ron
« Reply #44 on: February 15, 2018, 09:06:45 AM »
Ron...congrats...looks very nice...I hope to work you on 40....
  A couple things I want to comment on....
I like the PP output coils you wound ..If they were closer to the swinging link, wouldn't you get more output?
I notice you have the link "fully engaged".  If the coils were closer to the swinger, you could always back the swinger out a little....if it loads too much...
That gassy tube you have may still be usuable...One of the 100th tubes you sent me a few years ago was gassy and purple and even had a small purple torroid shaped doughnut that crawled up and down the long plate stem when in use....I used that tube along with a non gassy one in my PP 100th rig for about a year before I got a replacement..  I am on travel right now but I will be in the shack in a week or two....Steve
W8ACR
Penta 254W
« Reply #45 on: February 15, 2018, 10:42:39 AM »
Hi Steve,
Good to hear from you. It's been a while, hasn't it? I'm not sure which picture of the coils that you saw, but I did rewind them onto different forms and now are much closer to the swinging link. At 200mA plate current, the swinger is about 80% engaged. I can get quite a bit more plate current, but the plates get uncomfortably bright, so I keep the plate current low and don't push the tubes too hard. I ran it last night at 150mA, but I think up to 200mA is probably safe and that will also get the plate impedance down. I think I have the mod transformer set for about 6400ohms plate impedance.
I understand you are down south right now. Hopefully we can have a QSO when you get back.
73, Ron
W8ACR
Penta 254W
« Reply #46 on: February 16, 2018, 11:08:01 AM »
Could somebody please count the turns and also measure the spacing between the turns of a commercially produced 500W 40 meter plate coil (eg. TVL40 or equivalent). I have acquired some #12 enameled soft copper wire, and am going to try and wind a better plate coil.
Thanks, Ron
« Reply #47 on: February 16, 2018, 08:04:53 PM »
picture of 40 meter coil in my 250 th rig.. It happens to be on my computer..
« Reply #48 on: February 16, 2018, 08:34:56 PM »
  that's some girl.
KC2ZFA
« Reply #49 on: February 16, 2018, 09:12:24 PM »
Hi Ron,
I attach the official HDVL and TVL coil info. The TVL coil table columns are labelled as for the HDVL coils.
The starred footnote says "total effective capacity required to effect resonance on low frequency end of specified band."
Each half coil has 11 turns occupying (start of wind to end of wind) 1 11/16 inches. Separation between coils (where the link goes in) 13/16 inches.
Also note, TVL's are 250W  coils.
Peter
Pages: 1 [2] 3 4   Go Up
