March 29, 2024, 08:44:46 AM *
Author Topic: COLLINS PTO ALIGNMENT TOOLS NEEDED  (Read 6756 times)
W1KSZ
« on: January 25, 2018, 04:37:10 PM »
I have the drawing of the two tools required to align a Collins PTO, but in my last move I
somehow misplaced my Lathe and Milling Machine (it's a joke).
Does anyone have a set I could borrow or purchase ? Or, know of a source for these ?
Thx, Dick, W1KSZ
RolandSWL
« Reply #1 on: January 26, 2018, 08:22:31 AM »
I think this is what you want. Available on EBAY.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xcollins+pto+alignment+tools.TRS0&_nkw=collins+pto+alignment+tools&_sacat=0
Rol......
W1KSZ
« Reply #2 on: January 26, 2018, 09:31:49 AM »
I bought a set of those. Not even close.
Tnx for trying though.
73, Dick, W1KSZ
KA8WTK
« Reply #3 on: January 26, 2018, 10:14:05 AM »
http://amfone.net/Amforum/index.php?topic=31295.0
See if this link works and this is what you want.
Bill
Bill KA8WTK
W1KSZ
« Reply #4 on: January 26, 2018, 11:15:04 AM »
The tools shown in W4NEQ's response are the ones I am looking for. The other tools,
available on e-Pay, are alignment tools for the Receiver and not the PTO.
Tnx for the reply,
73, Dick, W1KSZ
N3GTE
« Reply #5 on: January 29, 2018, 09:44:41 PM »
Would think if you had some sm dia steel tube and a file you could fabricate the tool to loosen the lock nut. It's round tube with two protrusions on it. The tube allows it to fit over the slug adjustment screw. Getting the nut loose is the tough part. To make the tool the adjust the slug I would try using a piece of coat hanger wire that is flattened on the end and shaped like a straight screw driver tip.
GL
Terry N3GTE
W1KSZ
« Reply #6 on: February 01, 2018, 04:43:10 PM »
I looked into making one, the problem being finding tubing that is 0.2" OD. So far no luck.
73, Dick, W1KSZ
WD8KDG
« Reply #7 on: February 01, 2018, 08:44:55 PM »
73, Dick, W1KSZ
McMaster Carr
W1KSZ
« Reply #8 on: February 01, 2018, 08:50:14 PM »
Do you know that for a fact or just assuming ?
I spent some time over there and did not find anything.
73, Dick, W1KSZ
WD8KDG
« Reply #9 on: February 01, 2018, 09:06:27 PM »
73, Dick, W1KSZ
Top of their home page........at search area.............type in tubing.
https://www.mcmaster.com/#tubing/=1bdyubd
You name it, they got it.
Craig,
« Reply #10 on: February 01, 2018, 10:40:36 PM »
I believe 7/32 is what your looking for.
7/32 is about 5 thousandths larger than .200.
Take a peek at the McMaster Carr page I screen shot for ya.
Not sure if this MATERIAL will work for what you need, but if I can help you find something, lemme know.
nq5t
« Reply #11 on: February 01, 2018, 10:59:03 PM »
I have a set I made, along the lines suggested.  E.g., a piece of tubing of the right diameter (I don't recall whether it's brass or aluminum), notched to grab the nut.  I just used a screwdriver with a long thin shaft through the tubing.  I'd loan it to you, but after a relocation, I have no idea where my PTO stuff is … and it would take me longer to find it at this point than it would for you to just make one.
That said … I adjusted endpoints of probably a dozen of these PTOs over the time I was collecting/restoring.  You don't really need the tool — very thin bladed needle nose pliers will usually work ok for the nut.  The PTO is virtually impossible to adjust in the radio.  The only practical way to do it and retain your sanity is to remove the PTO, set it up in a jig of some kind (vise), with a half-circle fixed scale, a knob with a pointer (e.g, unfolded paper clip), a frequency counter, and external power or power extended from the radio.
Depending on how far out the endpoints are, you may have to remove one turn from the end-point adjuster coil, and that will require removing the PTO anyway.  Probably 30% or so of the ones I rehabbed required it.
W1KSZ
« Reply #12 on: February 02, 2018, 12:21:51 AM »
I got the end points down to less than 500 cps end to end. Very touchy to get it
that low.
Use of the tool to tighten the nut while holding the screw adjustment seems to be whats
needed.
I'll look for some tubing.
Thanks for the reply,
73, Dick, W1KSZ
W1KSZ
« Reply #13 on: February 02, 2018, 12:34:34 AM »
Thanks for all those trying to help, but I cannot find anything close to 0.200" at McMaster Carr.
7/32 = 0.21875, a tad to big to fit inside. The wall thickness needs to be 0.016", anything
smaller and you run the risk of bending or breaking those little extensions at the end of the tool.
I may just bring the drawings over to an acquaintance who has a small machine shop. Might be
worth it just to have both tools made. If the price is right there might be a market for them.
73, Dick, W1KSZ
