April 16, 2024, 03:27:58 PM *
Author Topic: Anyone using a Drake SW-4 or SW-4A?  (Read 5918 times)
Jim W8DRZ
« on: March 25, 2005, 07:17:32 PM »
Once again I'm chasing serial numbers in an attempt to
track the true production numbers of a Drake Radio and
I need your help.
If you are an owner of a Drake SW-4 or Drake SW-4A
this may be of interest to you.
 From published information I have always thought that
500 to 600 SW-4 receivers were built before the change
to the SW-4A version.
  I no longer believe this is true.
  I have acquired a SW-4A with a S/N of 451, this
then would mean that 450 or less SW-4's were built
before the change to the "A" version. I was surprised
to learn recently of a SW-4A with much lower SN.
 The owner was kind enough to send me plenty
of pictures of this radio, it is clearly a SW-4A
and sports the SN of 251.
  This would mean a much smaller number of SW-4's
were built before the change to the SW-4A.
Here then is my quest, To find more information about
the SW-4's true production numbers.
Do you own a SW-4 or SW-4A?
If so can you send me your SN and version?
Their are 4 versions of the SW-4A and it would
be fun to track the SN breaks on these as well.
SW-4A differences:
1) Earliest type has Dial window and PTO knob like a R-4A
2) Next version is like the R-4B in the Dial window/knob
3) The C-Line type Dial and knob is next.
4) The last version is minus the NewYork Radio WW logo.
 Almost 40 years ago in 1966 when the SW-4 first
appeared it was way above the means of a 14 year old
paperboy. I had to settle for a Knight-kit SpanMaster
at one-tenth the cost of the Drake. ( I still have it!)
  Still I dreamed of someday owning a Drake receiver
and like many of us now I do, many times over, HI!
I will post the results of the survey in a few weeks.
Jim - W8DRZ
WLRO, WOBL,
WBNO, WHFD,
WJW
« Reply #1 on: March 25, 2005, 08:25:54 PM »
Hi Jim,
Is it possible that Drake may have began the SW-4A sn sequence at or near 0001 Huh
Jim W8DRZ
« Reply #2 on: March 25, 2005, 08:53:31 PM »
Bud Hi,
            That is one of the things I'm wanting to find out.
I'm pretty sure they just kept on going from 001 with the
first SW-4 right into the SW-4A like they did with the R-4 and
on into the R-4A, R-4B and R-4C.
I have yet to hear of a SW-4 with a serial number above 225,
or a SW-4A below serial number 230. So I'm thinking that less
than 230 SW-4's were built.
I have collected 30 serial numbers  starting from 001 owned
by LA6OP to 2904. Not a very good sample yet, but a good spread
of numbers showing some promise on not only the "how many"
question of the SW-4 but also the different styles of the SW-4A.
Just a nitch that interests me.
Thanks for your input.
Jim - W8DRZ
WLRO, WOBL,
WBNO, WHFD,
WJW
Page created in 0.032 seconds with 18 queries.
