April 18, 2024, 01:22:19 AM *
Author Topic: Coil Turns Spacing & Wire Gage vs Power / Voltage  (Read 2579 times)
W9ZSL
« on: December 30, 2017, 02:40:06 PM »
I know there are charts listing plate spacing vs voltage for variable capacitors. Is there any chart or formula for coils in a Pi Network? I ran across this in my jonque box. It has a nice shorting switch. It appears to be 15-80 meters, is 2" by 3" with perhaps 16 or 14 gage wire. Turns are spaced 1/8" and it needs the separate 10 meter coil. This may have come from a Heathkit. How do I determine its power-handling capacity?
« Reply #1 on: December 30, 2017, 05:39:30 PM »
If the coil is 16 or 14 gauge it should be able to work to 100 Watts.
There are spreadsheets for Pi-networks but they don't determine power handling capabilities, they only give values for the Shunt-C, Series-L, and Shunt-C components.
How do you know it needs a separate 10 m coil? Have you measured the inductance and have a schematic of the Final stage?
Are you homebrewing?
W9ZSL
« Reply #2 on: December 31, 2017, 01:50:49 PM »
I was thinking of using it for an AM rig with parallel 5933s running about 120 watts. The switch is 5 positions. Each position shorts out one portion of the coil. In the fifth position, the entire coil is shorted so it will require a 10 meter coil.
W9ZSL
« Reply #3 on: December 31, 2017, 02:32:43 PM »
This appears to have come out of a Heathkit Apache so it can handle 180 watts CW and 150 AM.
« Reply #4 on: December 31, 2017, 03:10:04 PM »
No doubt about it.   Cool
Here is a pic of the RF cage from the Apache now on my bench for a Cap upgrade.
Phil
W9ZSL
« Reply #5 on: January 01, 2018, 03:09:20 PM »
That be it alright with a nice shot of the 10 meter coil.
W9ZSL
« Reply #6 on: January 02, 2018, 12:19:40 PM »
Thanks!
