June 24, 2025, 09:24:49 PM *
Author Topic: Window Line, Clearances??  (Read 2284 times)
W6TOM
« on: October 28, 2017, 03:36:48 PM »
  Going to replace my coax fed, 80/40 meter dipole with a Window Line fed dipole and I am now in the process of determining how to route the Window Line into my garage where the shack is. I've played with a the same type of antenna while visiting both of my sisters in MA, it seems the Window Line is not bothered by proximity to non metallic things but I wonder what clearances I should try to maintain from electrical (AC) conduits and low voltage wiring which will be an issue in my garage.
   Any suggestions?? Thanks!!
« Reply #1 on: October 28, 2017, 03:40:25 PM »
The rule of thumb I read was three times the spacing.
IE, if the window line is spaced 3ninches, then keep it 9 inches from anything.
I also tend to twist it gently when going near metal.  It's a lineman thing lol.
KA0HCP
« Reply #2 on: October 29, 2017, 02:07:48 PM »
Advice I've seen over the years ranges from 2-8 times the width of the balanced transmission line, with 2-4 times being suggested most often.
I haven't seen any engineering analysis justification.
