Caps for my RANGER II
February 18, 2019, 10:22:04 AM *
Author Topic: Caps for my RANGER II  (Read 996 times)
Knightt150
« on: September 25, 2017, 04:26:35 PM »
Hell: I am recaping my RANGER II I have found most of the caps except C69 .02 mfd at 1600 volts axel lead paper polorized  cap and C60 .005 mfd at 400 volts axel lead paper polorized cap.
can anyone help me on this?
Thanks John
W9BFO
kb4qaa
« Reply #1 on: September 25, 2017, 06:38:45 PM »
You may need to use a radial package and extend the leads.  For example:
594-2222-378-90053
Manufacturer Part #:
BFC237890053
Manufacturer:
Vishay / BC Components
Description:
Film Capacitors 5 nF
Knightt150
« Reply #2 on: September 25, 2017, 09:21:06 PM »
Sorry but the info you gave me I don't understand.
John W9BFO
« Reply #3 on: September 25, 2017, 11:09:14 PM »
Check Just Radios for what you need.  I know he (they) have what you need
The only problem is the minimum order is $20 bucks and they mean it.  I ordered about 18 dollars worth and they would not ship.  So if you can make up an order you are in business.
KC4VWU
« Reply #4 on: September 26, 2017, 02:34:15 AM »
Go to mouser.com and in their online catalog, select passive components. Then select capacitors, then select the type, poly, ceramic, etc.
Here's one that I found, you would have to enter this number in the search box.   PHE450XD5220JD20R06L2
.022 microfarad 3000vDC.
kb4qaa
« Reply #5 on: September 28, 2017, 02:26:57 AM »
John W9BFO
http://www.mouser.com/
I gave you the information for a cap that meets all your requirements except that it is radial.
Knightt150
« Reply #6 on: September 28, 2017, 08:54:31 PM »
Thanks for for all the help here.
John W9BFO
