This is for a table top piece cabinet to install your elec equipment like audio mixers or a receiver and maybe a tx if it's not to big.these were used in public dispatch like police/fire/rescue.these are still in good condx. made of a particial board and covered w/ a gray coating.these are heavy about 45 lbs.20.5" tall, 22.25"wide.this is 17" front to back at top and 22.25" at the bottom.the lower part is slanted.the top opening is 19"wide and 5.25 up/down and has many threaded holes to screw in items. the bottom opening is 19" across and 10.5" up down ,all the part you mount to is metal black rails all the way around w/ threaded holes,this part has a tilt to it for easy operation.has a vent on top and a hole on one side to let wires in. the bottom and back are open and this has metal rails top/bottom sides (inside) for added support.i have 5 of these.due to the weight and size will not ship will have to pick up. i am in central va.these are $50 each. Randy K4RHH
rwcradiocollector@gmail.com
