Yes, Tim's rig is built so well. In the previous picture back a
few posts, notice how he uses a front panel, a rear panel and
then bent a piece of aluminum into a "U" to form the chassis.
Very obtainable by most guys. One could even use angle channel
stock to bolt the sheets to for the chassis instead of bending it on
a brake.
BTW, Rich, you were axing about posting a picture yesterday.
You need to right click on your individual picture and select,
"properties". Then copy and paste the ".jpg. file that appears.
You used the page .htm adr instead, so it does not work. Everyone
makes that same mistake the first time...
Try right clicking
on your picture below and select "properties" to see the proper
adr appear for this use.
Here it is:
Yes, a FB Cakepan - and I see another in the background!
73, T
