April 24, 2024, 06:40:59 PM *
Author Topic: Knightkit V44 VFO Output  (Read 1473 times)
w9bea
« on: March 24, 2017, 02:09:02 PM »
Good Afternoon All:
I was wondering what I should expect as far as RF frequency output and amplitude out of a Knightkit V-44 VFO?
The manual does not tell me specifically what the fundemental RF output is; just rather tells me that it cover 80-10, and that the output is more than enough to excite the oscillator in a transmitter.  OK.
I am aware that it multiplies upwards depending on the intended xmit frequency via harmonics.
Just got done "rekitting" a basket case VFO, am about put it o the shelf and go to work on a soon to match transmitter.... Just want to make sure that the frequency output spec and RF level out is correct for this Clapp type Oscillator/Buffer.
Appreciate the insight.
73--Wally W9BEA
Wally Klinger W9BEA
Wklinn@hotmail.com
-or-
w9bea@arrl.net
« Reply #1 on: March 24, 2017, 05:22:55 PM »
Wally,
   The VFO is always running on 160m, and the buffer stage acts somewhat as a doubler. The RF output coils resonance is dependent on the VFO load capacitance, and cable (much like the Johnson 122). On a scope, open circuit is a complex waveform full of harmonics; it is not a sine wave. As I recall, the amplitude is upward of 100v P-P when connecting a 10X scope probe to the crystal plug pins.
   It is worth repeating, the VFO is always on 160m, and the output has a strong 80m output (rich in harmonics), no matter if the VFO knob is on the 80m, or 40-10m position. Getting on 10m with this VFO means 16X frequency multiplication. I also believe that the two output coils in the back are identical.
Wd5JKO
