March 29, 2024, 05:23:12 AM *
Author Topic: Ohmite Resistance in the Information Age  (Read 2344 times)
« on: March 14, 2017, 11:29:22 PM »
I've got a dummy load that is composed of (5)   OHMITE Non-Inductive  Vitreous Enameled Resistor Stock No. 2208. They are marked at 250 ohms.  Google is not my friend. None of my old catalogs, the current Ohmite online search engine or even the Google has any information fer me.
Watt I want to know is, What are these things rated for dissipation?  They are about 6 1/2 inches long........  My conservative guess is 100 watts.
Any help would be appreciated?
N0WEK
« Reply #1 on: March 14, 2017, 11:42:18 PM »
Well you could put 125 volts to the load which would give you about 312 watts, about 63 watts each, and see how quick they get hot. That will give you some idea of how far and how long you can push them.
Greg
« Reply #2 on: March 15, 2017, 12:04:29 AM »
They are 100  watters.  I have a number of them, I'll take a look and get back.
I'm back,  took me a half hour to find my Ohmite catalog.
Ohmite #2208 are 100 watters 250ohms.  They are useful throughout the BC band and higher frequencies depending on what resistance is being used.  The description doesn't add anything else as to what resistances are usable at higher frequencies.  Inductance is suppose to be less than 1% of that of regular power resistors.  The RF resistance is suppose to be the same as the DC resistance throughout the useful frequency range.
Very low distributed capacity and the change in impedance is suppose to be very slight throughout the useful frequency range.
Description adds that these resistors are use for dummy antennas (loads), antenna terminating resistors and used in diathermy equipment.
Should be mounted with non-magnetic brackets.
Hope this helps
« Reply #3 on: March 15, 2017, 07:17:13 AM »
Hey Fred, any chance that there is a photo in that Ohmite catalog of the "Ohmite Girl"? I've heard that years back, she would show up at trade shows wearing a color coded outfit.
« Reply #4 on: March 15, 2017, 12:29:22 PM »
Thank EVERYONE .....  thats watt I wanted. So I've got a nice 500W dummy load. I vonder if adding a muffin fan would boost the dissipation..
KLC
« Reply #5 on: March 15, 2017, 12:44:39 PM »
Add a fan to increase the dissipation BUT those resistors should never be loaded to the full rating.  Maybe 250-300 watts with the fan for short periods.
