April 23, 2024, 10:23:59 PM *
Author Topic: Measuring Cap Plate Spacing?  (Read 1634 times)
Carl WA1KPD
« on: February 10, 2017, 02:12:14 PM »
When measuring the cap plate spacing to determine the voltage capability of a HV variable cap, is the distance specified in articles and catalogs:
  • The distance between any two plates in the same part, i.e stator plate to stator plate
    The distance between a stator and rotor plate?
Obviously it has a 2X or 50% impact on the voltage calculation.
« Reply #1 on: February 10, 2017, 06:17:28 PM »
Distance between stator and rotor.  1/4" has a rating of 9KV peak.  The distance between two stators or two rotors would be 1/2" plus the thickness of the plates,  this is for a 9KV cap.  Other caps would be figured the same way.
Carl WA1KPD
« Reply #2 on: February 10, 2017, 07:29:45 PM »
Appreciate it Fred.
