PS Reactor substitution
January 27, 2021, 06:02:26 PM *
Author Topic: PS Reactor substitution  (Read 3257 times)
xe1yzy
« on: March 09, 2005, 01:53:09 PM »
The reactor in the PS of my BC610E are lost, the value is 11h/55ohms/0.5amps, I have available 2 reactors the value of both are 6h/250ma/90ohms, can if I put in series both as  a substitute?
what do you think guys?
or  you have any other idea  :idea:  ?
Regards
TVI WHAT TVI?
« Reply #1 on: March 09, 2005, 02:07:11 PM »
not enough current. Many guys increase the value to the plate supply filter cap to reduce hum. Without a choke your supply will be 2500/3000
volts.
xe1yzy
« Reply #2 on: March 10, 2005, 10:02:53 AM »
Tnx Frank
Problem is solved, yesterday I found the choke , not exactly the same, but is a huge one, .5  amps too, hope works!
Regards!
TVI WHAT TVI?
Page created in 0.03 seconds with 18 queries.
