Jerry
The manual (including the schematic for the box, but not the sensor) is here:
http://www.qsl.net/kb7tbt/manuals/yaesu/ys500%20manual.pdfDoes the sensor have a separate part number on it?
Separately, this reference should be helpful:
http://vk5ajl.com/projects/swrmeter.phpNote the sentence below the diagrams:
"The terminating resistors are critical but only in so far as they should be the same and somewhere near the correct terminating value for the width of the pickup strips.
The correct value can be estimated using the formula above the diagrams:
"Z
0 = 377 x (t/w) x E
r-0.5
where t/w is the ratio of thickness of the thickness material to width of the strip (so inch, mm or cubits doesn't matter) and E
r is the relative dielectric constant of the material... which for a fiberglass PCB circuit board is about 4.5."
Edit by Stu:
I'm not sure that I agree with the reference's author regarding the values of the terminating resistors. For a symmetrical coupler, both resistors should be the same... but the two terminating resistor values should be chosen as follows.
1. Connect the coupler's RF output port to a 50 ohm dummy load, and apply power at the RF input port. Measure the voltage produced at the "reflected power" output measurement port.
2. Adjust the value of the terminating resistor across the "reflected power" strip line to cause that voltage to be essentially zero.
3. Use the same value for the other terminating resistor.
