February 11, 2026, 07:58:26 AM *
Author Topic: Potentials for new ham shack  (Read 29063 times)
k7mdo
« on: October 16, 2015, 06:27:10 PM »
Having the room and the impetus (wife) to head out to my barn to build a new ham shack, and while I am cleaning out an area to start construction, a couple of thoughts occur.
One is overhead lighting, with the apparent move away from incandescent what would be the best option for low interference? I have flourescent in the current location with no obvious noise other than the transformer hum.  Any suggestions?
I am setting aside a 12' by 12' area with 8' ceiling.  It will be new interior type construction in side of my existing metal sided barn.  One wall will be the exterior sided wall, the other three will be newly constructed as will the ceiling.  What, or would there be, an advantage to building it as a Faraday cage?  It would be easy to do now, rather than later...  any thoughts on this?  Seems to me from a previous job I did we used very fine copper screen electrically bonded everywhere.  Seems like that might be a bit expensive.  How about chicken wire, cheap and easy to put up before the drywall?
Thoughts?
73, Tom
« Reply #1 on: October 16, 2015, 06:52:52 PM »
I had to check your call,  Tom.   A friend,  named Tom,  is doing the exact same thing!
The one thing I'll mention is,  insulation.   Insulate the entire room,  and insulate it well.   On all 5 sides.
Makes it much easier to cool and warm that way.
Also,  as many outlets as you can figure.   Then double them.
I have an isolated ground in my shop.   Keeps the nasty phone chargers,  laptop chargers,  etc noise out of the radio room.   Not perfect,  and has associated drawbacks, but a clean ground is a beautiful thing.
Plenty of home run 20 amp circuits. All outlets in my shop are 20 amp.   My test equip runs on a gfi protected 20 amp dedicated,  I have another 20 amp test plug,  with a variac in line,  and a string of 20 amp plugs around my work bench.
The operating position has a and b phase brought over and split.   This means every other plug is it's own circuit,  sharing a neutral.
Then I have a couple 220 outlets.   A 30 amp for my Harris,  a spare 30, a 100 amp,  and a couple 20 for legal limit stuff.
The workbench has a 20 a 30 and a 100 amp 220.
All fans and lighting are on a seperate 15 amp.   One for interior and one for exterior.   Exterior has a light sensor that fires a contactor that turns all my exterior on at dusk.
All encased in Conduit,  sans lighting runs interior to the shop.   Those are standard 14/3.
Chicken wire as a Faraday cage is useless.   If it was any good,  every stucco home would be shielded.
Install a good ground.   It will pay off in spades.
The system I describe above is overkill for most people.   For me,  it was free,  sans labor.   I'm an electrician.
« Reply #2 on: October 16, 2015, 07:01:53 PM »
Hi Tom,
I don't think you need the shielded room!  One thing I would definitely do is insulate your space.  If your going to frame it out, put some fiberglass in the walls and ceiling.  The other suggestion is think about the size of the shack.  Make it larger than 8 X 8 if you can.  It may look big enough, but it will fill up quickly.  On my rooms I also insulate the floors between the floor joist and use some good sub flooring.   If its being built on a slab, I use a concrete sealer followed by felt paper and then cut foam insulating panels to size and put them between the floor joist.  What you will have is a very comfortable operating space when done.  You can figure out your heat and cooling source.  Here are a few pictures from my latest room working museum radio room downstairs.  This is room 1 of 3.
k7mdo
« Reply #3 on: October 16, 2015, 11:44:45 PM »
Wow, thanks for your thoughts.  Insulation will be on all walls and power will not be a problem as the service is shared with my machine shop and the shop actually consumes very little power especially if I'm going to be in the radio room!
I have a 25 amp isolation transformer that I have always used on my workbench  with the boat anchors especially. I will build it into the workbench in the shack.
The floor is concrete.
Lighting is still a question.
I haven't tackled the ground thoughts yet.
Tom
« Reply #4 on: October 17, 2015, 12:56:12 AM »
In the topic name I keep thinking about your B+ arrangements..
« Reply #5 on: October 17, 2015, 08:39:01 AM »
I have bought over 60 Cree led 60W bulbs .... perhaps 1 of them has failed ... I love the light (3000A) from them and if you keep looking can get them for $3 or so .... bulb fixtures are cheap and plentiful
the Cree bulbs are UL apvd and electrically quiet ... the bulb envelope feels weird though
« Reply #6 on: October 17, 2015, 11:56:02 AM »
I'd skip the chicken wire. Too many rusty joints that could create noise or RFI. If you want a shielded room, use foil backed drywall. Get aluminum tape and tape each joint or overlap the drywall sections. That said, shielding is probably not needed. You be better served by putting in a good ground system and filters on your power lines. Lots of good info on the at the link below.
http://amfone.net/Amforum/index.php?topic=40738.msg297350#msg297350
« Reply #7 on: October 17, 2015, 10:48:02 PM »
Thoughts?
73, Tom
Tom,
   Every situation is different, and everyone's wants can be all over the place.
What occurred to me while reading this post was how the hobby and XYL's desires were isolating you from her, and her from you. For many of us, that situation might be ideal, and for others it might not. For example, what if you are in the Barn and something happens...she falls, a prowler comes in the house, or you get across the B+, or have a heart attack.
Perhaps a compromise could be worked out. You thin out the ham shack in the closet to one neat station. Then she goes through her clothes and weeds out stuff that just isn't used anymore. This way, you can keep hamming in the house, and she can hang some clothes in the closet that would also deaden some of the noise from your ham station.
The room in the barn could then be used for storage, workshop, for both your ham gear, and for her surplus clothes.
Just one mans opinion.
Wd5JKO
« Reply #8 on: October 19, 2015, 10:48:27 AM »
12'x12' will be fine if you're dealing mainly with small equipment. If you have much big iron or plan to build benches, it might fill up pretty fast as Joe said.
Fluorescent shop lights have worked fine for me, though a couple of times when they were warming up from a cold night, they did make a bit of buzz. Choice of lighting really depends on the space and what kind of lighting you want. Beware of some CFLs - they can indeed be very dirty in the RF sense. We have LED bulbs in the house that make zero noise. Can't remember the brand.
Definitely don't sweat the Faraday Cage as mentioned. The bigger issue today is introducing noise into your station through the power and feed lines. An ounce of prevention there is worth many pounds of cure later.
Don't neglect the insulation and climate control, either. I had a rude awakening here in NC when I walked out into my unheated station during the winter. Temperature swings had caused condensation on virtually every piece of equipment. A space heater, a pile of towels, and several hours later it was cleaned up. A clear case of getting the station up and running before finishing the space. Not smart.
I'd also suggest using the dual outlet boxes when you wire. Better to have too many than a bunch of outlet strips or extension cords hanging around.
k7mdo
« Reply #9 on: October 19, 2015, 11:18:02 PM »
It seems the best I can squeeze out of the area will be 10+ by 12.  Not totally happy with that but it is what it is.  I will post frame pictures when they are together.  Just now worrying about using concrete nails or screws or ? for the sill boards.
As to the alienation from the wife, well I have talked to her about it and first thought is an intercom or such... the B+ and heart attack issue will have to wait.
In the meantime the Rickreall ham fair is this weekend and there comes another interruption!
N9axl
« Reply #10 on: October 20, 2015, 10:10:30 AM »
I think the dual outlet boxes are a good idea.  In my case I am considering putting in an L shaped desk with a 9 foot operation position and 4 feet for equipment repair.  My issue is that I have a total of one ungrounded outlet in the room.
I have an GFCI outlet on the other side in my current operating position. I'm going to have to have an electrician install some more outlets.  In my case my issue is I have a 1950s house with 2 prong ungrounded plugs.  My joke is I bought a house that matches the plug on my Heathkit DX-20. (and actually I am in the process of replacing all those plugs with grounded and fused line cords - I have no interest in dying for nostalgia's sake)
I plan to have GFCI outlets installed in the new position and wire them to a wall switch so I can turn off everything with one click. I have mostly 1950s equipment and, as a rule, it all stays unplugged unless I am using it.
« Reply #11 on: October 20, 2015, 02:19:00 PM »
It's pretty close to true that you cannot have enough electrical outlets in you shack.  Be sure to include a 220 outlet in case you want to add a 'LEEENYAR"
I put full HVAC in my new shack - so glad I did. Comfy both in summer and winter + better efficiency.  I put an 8" 16lb copper sheet under the wall plate.  The outside part of the sheet is attached to my ground system.  After construction the plate was bent upward so that a 5/8" copper pipe could be  attached.  That pipe goes along the back the wall in a "L" fashion so I can have a common ground point for all my gear
Al
« Reply #12 on: October 20, 2015, 02:31:14 PM »
RF tends to trip the GFI stuff.
I have 2 quads fed by #10 to their own 15 amp breakers and its not enough, I have outlet strips that are connected to the master on off switch for the small stuff, the big rigs get their own switch and outlet.
Unless all you have is small stuff, you need at least two 15 amp feeds and as many outlets as you can.
House wiring is much easier then ham radio equipment, so why not do it yourself?
Hot, neutral, ground, #10 or #12 wire, white is neutral, black is hot, bare is ground.
Get 20 amp switches and outlets, and they also make GFI breakers.
N9axl
« Reply #13 on: October 20, 2015, 04:51:35 PM »
The problem I have isn't that I couldn't do it, but my insurance wouldn't pay off if there was a problem on something I did and the city codes don't allow any house to be sold with "do it yourself" wiring of any type. If I ever wanted to move I would have pay an electrician to either remove it entirely or remove it and reinstall it.
k7mdo
« Reply #14 on: October 20, 2015, 06:37:40 PM »
Progress today... but waiting for a new framing nailer to arrive before the uprights go in.
The concrete attachment was easy part as the local builder's hardware pointed me to the right drill bit and some hammer driven studs.  Fun so far and only issue is that the two walls I need to attach to are previous construction by the first owner.  I have to cripple into the walls on one side.... learning experience but my neighbor was in the building trades so I can bounce ideas off of him.
Next is to plot out the AC 120 and 220.... I have all the wires available to me in the current shop so I only have to do a sensible layout.
Also pictured is the first box of stuff for the ham fair coming up this weekend....
Tom
Oh, and the wife in front of me on a bicycle trip we did on the Dempster highway this summer.
« Reply #15 on: October 20, 2015, 10:23:10 PM »
Tom
Tom,
Unless the plate you put down over the concrete is pressure treated it will rot.  You might not thing you have any moisture issue since with air over concrete it evaporates before you can see it.  But, when you cover it up the moisture is trapped and in time it will rot and you will also likely have mold.  Go up and look at my previous post and if you don't want to take the steps I did, at least put treated lumber down.  Drylock works well also as a moisture barrier.  Hate to see you go to all the work and then have problems down the road.
Joe-W3GMS
k7mdo
« Reply #16 on: October 21, 2015, 12:00:30 AM »
Joe, it is pressure treated.... the building in the past has been subject to a little water but I added a sump pump a couple of years ago and so far "no problems".... hoping for the best but preparing for calamity!
AB3L
« Reply #17 on: October 21, 2015, 07:24:25 AM »
If the floor had not been poured yet I would have suggested Pex tubing in the pour run to an instantaneous heater like I have in my addition. Thermostat triggers the circulation pump.
The local tile store has an entry ramp with ceramic tile that melts snow. There is a spun fiber sheet with heat coils on it that is placed under tile ....if that might be a consideration. Nothing like heat under foot.
But....I don't know what interference you might encounter from the coils.
K2DUV
« Reply #18 on: October 21, 2015, 08:15:15 AM »
A wonderful project!  I am thinking of doing the same in my garage where I have room for an operating position.
I recently reviewed the National Electrical Code and prepared a presentation on grounding for my local ham club the Rappahannock Amateur Radio Association.  I will make this a separate posting.  Everything can be improved, so I welcome comments on the presentation.
I REGRET THAT I CANNOT POST THIS PRESENTATION BECAUSE THE FILES ARE TOO LARGE TO BE POSTED. If anyone wants copies of these presentation please contact me at fhh11@columbia.edu
73, Floyd
« Reply #19 on: October 21, 2015, 08:35:42 AM »
That does not seem legal.
They might require a permit and inspection, but even in NJ people build their own garages, additions and houses.
N9axl
« Reply #20 on: October 21, 2015, 08:45:17 AM »
Doesn't seem legal I also have to buy a city permit to park in front of my own house but I do. At least I'm not in an HOA.
« Reply #21 on: October 21, 2015, 02:16:51 PM »
We have a similar problem here in Bakersfield city.
Here,  it's legal for a homeowner to do pretty much anything,  as long as it's permitted and inspected.
The kicker is,  ONLY in electric,  they won't ISSUE a permit unless you have a valid electrical contractors license.
Not a valid,  California licensed electrician.   A valid electrical contractors license.
Magically,  though,  in the COUNTY, a homeowner can permit and do the work himself.   In the city,  a homeowner CAN do the work,  but you have to have an electrical contractor there for any permits and at inspection time as well.
« Reply #22 on: October 22, 2015, 08:09:30 AM »
Good on the pressure treated plate.  You should be in good shape.  I learned this lesson the hard way down in my museum.  We have never had a drop of water in the basement, so I put down untreated lumber for the plate.  Some years later I opened up the wall and looked at it and it was all rotten.  I had to rip it all out and this time did it right.  My point only being that even concrete surfaces that appear to be bone dry, still have moisture wicking through the concrete.  When its not covered it dries so quickly that you do not even though that its present but it is!
Good luck with your project and enjoy your new space.
Joe-GMS
« Reply #23 on: October 22, 2015, 03:32:56 PM »
I think pressure treated will still rot, you need a vapor barrier, no?
I thought pressure treating was for bugs.
When I made a den in the basement, I did oil base paint on the walls, then plastic barrier, then insulation, even though it is somewhat ventilated.
The floor I just put a rug on, if a rug gets wet you can dry it, clean it, or get a new one.
The one time I had water in the basement is was from a water heater leak.
The floor does not get very cold with a rug on it, or even without if the space is heated.
Heavy racks and shelves like to sit on concrete and I loose no space.
I painted the floor before all the stuff got moved in.
N9axl
« Reply #24 on: October 26, 2015, 11:37:39 AM »
The issue is that any lumber, even pressure treated, has moisture.  Typically, lets say 20% moisture, and you are putting that in a heated space.  That moisture is going to come out with the heat. If it's wrapped in plastic that moisture stays next to the wood and will, eventually, rot it out - or, more likely rot out the associated wallboard, plaster.  Ever see a bathroom pipe leak into a basement ceiling?  Within a few week you get mold, etc.  Same idea.
Page created in 0.074 seconds with 19 queries.
