PDM rig construction updated 2/7/05
March 07, 2021, 04:06:33 AM *
Author Topic: PDM rig construction updated 2/7/05  (Read 11322 times)
W1IA
« on: February 06, 2005, 05:29:36 PM »
Making progress...many thanks to young Bill KE1GF for his technical assistance.
https://home.comcast.net/~w1ia/
Run What Ya Brung!
wavebourn
« Reply #1 on: February 06, 2005, 06:41:31 PM »
Looks very impressive!!!
« Reply #2 on: February 06, 2005, 11:42:24 PM »
Keep a close watch on those PVC coil forms for any sign of overheating.
"Let's go hiking in the woods, Tommy!" - Yaz
« Reply #3 on: February 07, 2005, 12:36:42 PM »
Vely Vely nice, Brentina!   I like the custom welded frame enclosure. Oughta be a nice looking unit when finished - and strappingly built too.
A few comments...
The PDM coils will be A-OK on the PVC pipe since they are running only 110 kc through them. I use the exact same set up as you are - even the red #6 wire.  They run cold.
But, the coupling between the two coils placed side by side is going to create some feed-thru problems. It will show up as "pilot carriers" up and down 110kc from your frequency. Probably down only -60 db or so.  I isolated my coils farther apart, at right angles, and even placed them outside the cabinet away from obstructions and initially only achieved about 60db of switching freq attentuation. I ended up putting in a 110kc resonant series trap right at the final B+ input which sucked it down to an acceptable -130++ db. It cud barely be heard on my own RX afterwards.
Also, consider adding some more drain bypass caps. I see only one per module. (500pf?)  I have the same layout as you, including the plexiglass holding the output transformers.... and found I need about 1500pf total to get a nice output waveform. Even 2000pf/per might be OK, depending.  Also, with the high current they draw, you need to spread the heat out amongst a few more, physically, if your intention was to use only one with a higher value...
Other than that, it looks great .  Post more pics as you progress, OM..
Yours will be the exact same config as mine - I'm so glad I built it.  Powerful, efficient, cool running, quiet - everything you want for AM. Just missing the glow, caw mawn.
The JJ PDM Rig meltdown last year:
And, the completed RF deck with the extra fet module spare:
http://home.comcast.net/~k1jj/wsb/html/view.cgi-photo.html--SiteID-1471619.html
Later -
Use an "AM Courtesy Filter" to limit transmit audio bandwidth  +-4.5 KHz, +-6.0 KHz or +-8.0 KHz when needed.
Nothing like a new homebrew rig. Come into the shack, flip on the switches and everything works perfectly.
And, nothing like an old dog.
« Reply #4 on: February 07, 2005, 03:43:23 PM »
T,
Those FET's look like a pile of spent roaches in an ashtray.
B
Quote from: K1JJ
Later -
Home of GORT. A buddy of mine named the 813 rig GORT.
His fear was when I turned it on for the first time life on earth would come to a stand still.
wavebourn
« Reply #5 on: February 07, 2005, 03:48:06 PM »
Quote from: W1RKW
T,
B
I had exactly the same impression... Dead bugs... Wink
« Reply #6 on: February 07, 2005, 03:50:18 PM »
Actually, I didn't have dead bugs in mind.
W1DAN
« Reply #7 on: February 07, 2005, 05:31:04 PM »
Hi Brent...
Good to chat last night.
I looked at your pix and it looks very good. It will probably work just fine as you are building it.
A couple of thoughts...
On the pink output transformer secondary ground...consider adding copper flashing to the center of the 4 groups of copper source busses and take the output ground from the center of the copper. The location of where you are taking tis from the heatsink may not be optimum.
On the PDM filter coils, if you do not have enough 100kc attenuation, maybe add a shield between the two coils that are paralell. I still like the idea of a series trap like K1JJ did.
Your caps should be in the mail this week. 3 4.7uf 1KV mylars and two 0.15/2kv drain bypass caps.
Dan
W1DAN
kc2ifr
« Reply #8 on: February 07, 2005, 05:50:35 PM »
Isn't there a web site dedicated to the class e stuff?Huh Do we have to see it here?Huh
Only kidding Brent........ :-P
W1IA
« Reply #9 on: February 07, 2005, 06:49:11 PM »
Quote from: K1JJ
A few comments...
Later -
Tom....I used 1000pf doorknob shunts, same as young Bill. Perhaps a piece of aluminum as a shield between those parallel filter coils? Otherwise I could run them vertically down the back with more separation....this is going to be tough if I need proximity separation and isolation.
Brent W1IA
p.s.   I finished the RF driver and the new photos are on the site
Run What Ya Brung!
W1UJR
« Reply #10 on: February 07, 2005, 07:01:58 PM »
Quote from: K1JJ
Hi Tom,
Did all those FETS crap out at once, or is that the result of some trial and error design?
Not being a Class E or Christine might argue "Classy" guy, what did those puppies cost? Looks expensive.
-Bruce
wavebourn
« Reply #11 on: February 07, 2005, 07:02:14 PM »
Quote from: W1IA
Perhaps a piece of aluminum as a shield between those parallel filter coils? e
Box or can, for better magnetic shielding.
« Reply #12 on: February 07, 2005, 07:50:53 PM »
Hi Bruce,
That crap-out was all at once.  It was my own fault that it got so bad.  The protection circuitry was shutting it down, but I couldn't see where the arcing was coming from. So, just like tube gear, I kept keying it wanting to see it blow out so I cud find the cause easily.  Two bad fets turned into a big handfull very quickly...  :lol:
But up to that point the four modules were running at different currents - no balance. When I replaced them the rig ran MUCH better and balanced. So perhaps I had a problem in there left over from initial testing that was ironed out the hard way. Cost, cheap - about $1.50 per fet.
Brent, I tried shielding between coils while watching the feedthru on the scope and it had no effect at all. Not sure why, but by better placement I got it to -60db down. That is still not great. Other guys did not need a series trap like I did to achieve -130 db , but whatever does the job...
For bypass caps, I ended up using 1500pf caps /module and Frank even suggested 2000pf. But since Bill/GF got away with 1000pf for the same design, it tells me that it is a custom thing and you just add them until the waveform and power eff is optimum.
If you run that rig at max QRO, I'll bet the single 1000pf gets too hot for comfort.  I wud use two 500's, one at the top and one at the bottom of each module. I added one in the center too. But, then again, take a look at the picture above and decide if you wanna take my advice, caw mawn... :lol:
« Reply #13 on: February 07, 2005, 08:14:35 PM »
I agree more shunt C Brent. Remember drain bypass becomes part of the output filter C so you may have to change the output cap to a lower value. looks good!
Blowing FETS: The later the hour the louder the bang!!!!
KM5TZ
« Reply #14 on: February 08, 2005, 08:06:34 PM »
Quote from: K1JJ
Hi Bruce,
Do you have any numbers? I'm curious how much of an improvement you got in efficiency with the additional shunt cap - and the change in pk drain voltage also?
I'm building a 3 band Class E tranmsitter (160/80/40m) so some compromise is expected - I switch in/out shunt caps with high current relays.
David.
KM5TZ
« Reply #15 on: February 09, 2005, 01:45:48 AM »
Quote from: W1DAN
Hi Brent...
Dan
W1DAN
The output is transformer coupled. It does not need to share the same DC ground as the FET's. I'd recomdend the output ground be bolted to the ground in the vicinity of the output tank network. Just my 5c worth - looks very nice!
David.
« Reply #16 on: February 09, 2005, 08:56:07 AM »
I agree with the secondary to avoid RF current loops.
Additional shunt C will allow higher output power that is stable.
I'm running about 5000 Pf per 11 FETs which is 1 phase. I can
easily get 1200 watts of stable carrier  at  46 volts.
Output coil pretty hot so efficiency is only 83% I figure I could gain 3 or 4
% with a better inductor. This agrees with NU2B software.
The RDS on hurts efficiency at high power running 47 volts
so 1000 watts is better efficiency.
« Reply #17 on: February 09, 2005, 11:23:09 AM »
Quote from: KM5TZ
David.
Hi Dave,
I don't have any actual numbers, just observations on the scope and wattmeter in general.
The caps really cleaned up the waveform, not sure if it did anything for efficiency - never correlated it.
What I did was tune up the rig for the best looking class E waveform. I tried for a textbook look with the nice clean peak and the lower base hugging the bottom as shown on the class E site.
Then I checked the power in vs: power out.  I adjusted the tap on the tank coil , thus changing the L/C ratio.  I added output bypass caps or subtracted them.
Eventually you will find a sweet spot where everything comes together... the power out  eff is high, the waveform looks perfect, the tank coil does not get too hot (optimum Q for situation) and the positive peaks are clean and high, etc.
It took me a good day of fussing, but it was worth it. I don't even look at the E waveform anymore, just the modulated RF envelope like any other AM rig.
I think everyone needs to go through this since all rigs are a little different even if they use the same number of fets, etc.
Also, if you go PDM, check your 100kc sidebands and if needed, add a series trap across the modulated B+ to ground. I needed it and now the supression is down about -130db.  I can post values for the L and C if needed.
Hope this helps.
« Reply #18 on: February 09, 2005, 11:41:27 AM »
Tom and I did this effort in parallel with two different configurations.
I arrived at a higher shunt C because my power supply was only cranking out about 47 volts and I wanted to make a clean stable 1 KW carrier.
This meant my Drain Z was a bit lower than Tom's.
Tom ran a bit higher voltage so didn't need to run his drain Z as low meaning he didn't need to increase his shunt C as high.
We both arrived at the same conclusion that more shunt C is required for stable operation.  I also found the load cap value needs to be above 1500 pf in my case. I used a 1000 pf vac cap with 1000 pf fixed in parallel.
Series cap is 500 pf vac at almost 400 pf. Tom's cap values a bit lower if I remember as his Z is a bit higher. I thought we both tracked well in our conclusions. Tom's efficiency was a bit better as my load Z was only 10 times RDS on so the resistance of the FETs were coming into effect. fc
W1IA
« Reply #19 on: February 09, 2005, 03:04:52 PM »
Quote from: K1JJ
A few comments...
Later -
Well...after some pondering I have mounted the filter on the back of the rack cabinet....now aprox 1 plus foot of separation between the inductors.
I will move the secondary ground to the rf deck when it gets mounted inside the rack. Thanks for the tips guys!
Brent  W1IA
p.s. new pic on website
http://home.comcast.net/~w1ia/
Run What Ya Brung!
« Reply #20 on: February 09, 2005, 03:32:51 PM »
Brent
The Secondary lead has a lot of RF current on it. You want both ends going right to the tank circuit with short leads.
I really think you need more tie wraps on the driver transformer
Hi Hi FB OM  WX fine here after school but I an a nerd in the basement
and my mom is yelling at me. "Egor come up you need light"
LOOKING GOOD!
Page created in 0.064 seconds with 18 queries.
