Offline
« on: March 07, 2015, 05:23:50 PM » |
The more load you pull, the better they smell! 73DG
KA0HCP
Offline
« Reply #1 on: March 07, 2015, 06:32:35 PM » |
Parallel Tubular!
New callsign KA0HCP, ex-KB4QAA. Relocated to Kansas in April 2019.
Offline
« Reply #2 on: March 07, 2015, 07:16:57 PM » |
Get yer 3-phase weenies here, cooked to order 73DG
Offline
« Reply #3 on: March 07, 2015, 07:28:08 PM » |
Get yer 3-phase weenies here, cooked to order 73DG Dennis, you've been out in the Sun too long, you need to come inside. Fred
Offline
« Reply #4 on: March 07, 2015, 07:31:32 PM » |
K9DXL
Offline
« Reply #5 on: March 07, 2015, 08:54:13 PM » |
And when you're done cookin', just flip the switch and slice 'em in half!
Breathing solder fumes since 1959. That explains a lot.
WB3JOK
Offline
« Reply #6 on: March 07, 2015, 09:50:52 PM » |
Presto used to make a hot dog cooker (called the "Hot Dogger" I believe) that worked just like that one. Passed the AC line voltage through the hot dog to heat it...
KE5YTV
Offline
« Reply #7 on: March 08, 2015, 03:51:37 AM » |
My family had a Presto Cooker. It was a wennie killing mofo!
Mike KE5YTV Dallas, TX "The longest trip begins with a stop at the ATM."
N0WEK
Offline
« Reply #8 on: March 08, 2015, 04:57:46 AM » |
Presto used to make a hot dog cooker (called the "Hot Dogger" I believe) that worked just like that one. Passed the AC line voltage through the hot dog to heat it... In the 50s we made those in shop class. A board, a line cord and two nails; it cooked the hotdog great but left the ends cold. Not the safest thing to use, can you imagine what would happen today if you did that in school, of course they don't even have shop class anymore! http://www.chiefdelphi.com/media/img/20f/20ff0eb9638792742b5bef80bcfe1d7b_l.jpg
Offline
« Reply #9 on: March 08, 2015, 08:08:42 AM » |
No they have home-EC classes for all. You learn to sew and cook.
Back to the basics of three phase fusible links:
"The skin is on the inside when you burn them inside out."
RICK *W3RSW*
Offline
« Reply #10 on: March 09, 2015, 12:01:06 AM » |
That one is for Vienna sausages!
Offline
« Reply #11 on: March 09, 2015, 10:39:31 PM » |
Are the dogs polarized such that in a DC circuit they have to be inserted correctly to allow current to flow? With plugs and jacks we sometime use the male and female analogy. Maybe that applies here as well. Jim Wd5JKO
Ralph W3GL
Offline
« Reply #12 on: March 11, 2015, 05:37:00 PM » |
Presto used to make a hot dog cooker (called the "Hot Dogger" I believe) that worked just like that one. Passed the AC line voltage through the hot dog to heat it... I have one of those "Hotdogger" 's stashed away in the bottom of my kitchen cabinet along side of my Sunbeam Electric Skillet and bun steamer... The hotdogger would cook 6 dogs at a time but I only used it for 2 most of the time... As I recall, it did a good job on the dogs. Think I might pull it out and try it as I have a package of wheenie's in the frig needing to be consumed... And, the buns are a bit "long-in-the-tooth" so the steamer will be used as well...
73, Ralph W3GL
"Just because the microphone in front of you amplifies your voice around the world is no reason to think we have any more wisdom than we had when our voices could reach from one end of the bar to the other" Ed Morrow
Offline
« Reply #13 on: March 12, 2015, 11:00:46 AM » |
Safety First! always use a fuse, current limiter, and isolation transformer, etc. DIY a 120-240 step up and variac with a light bulb or ceramic cone limiter. This works for the pickle lamp as well.
Offline
« Reply #14 on: March 12, 2015, 12:23:49 PM » |
To think this started out with a simple knife switch and some Kosher dogs.
It is always amazing just what will grow when you feed it...
Too funny!
WB3JOK
Offline
« Reply #15 on: March 12, 2015, 12:35:14 PM » |
Is the 300W series heater element placed in thermal proximity to the hot dogs, to help them cook?
Offline
« Reply #16 on: March 12, 2015, 01:09:34 PM » |
No, the 300W cone load is to warm the buns.
I don't like the variac. One could walk away from cooking, and come back to a shriveled up doug. Better to stay around and watch the quick cook. Fast food is watt made America grate.
Offline
« Reply #17 on: March 12, 2015, 01:28:28 PM » |
Now class, get back to the curriculum; this is a polyphase exercise, so make your efforts to that end. There will be a pop quiz on the horizon. Class dismissed. 73DG
WB3JOK
Offline
« Reply #18 on: March 15, 2015, 12:41:29 AM » |
Yeah, nothing worse than a shriveled doug.
n1exi
Offline
« Reply #19 on: March 15, 2015, 11:49:46 AM » |
seen this in an old issue of QST - some one had the bright idea of placing a two meter antenna inside of a metal garbage can - fired up the rig to cook a hot dog - field day? greg - n1exi
Offline
« Reply #20 on: March 15, 2015, 09:44:37 PM » |
Guy like that.. Does he still have the box his ham radio came in?
KA0HCP
Offline
« Reply #21 on: March 15, 2015, 10:51:00 PM » |
Why not just skewer the hotdog on the antenna? Much simpler. Of course, don't use a Larsen Kulrod!
