I am continuing my annual shack clean-out, and I have the following filament transformer that is now surplus to my needs:
A tested Stancor Chicago potted and "Sealed in Steel" Model F-520HB 5 volt at 20 amperes center-tapped secondary, with a 115/230 VAC single-phase primary. This high-quality transformer would be perfect for your 4-250A, 4-400A, or any other final amplifier or modulator tube requiring this kind of voltage and current. The secondary winding is rated for 10,000 volts.
This unit is about 5-3/8" W x 4.5" D x 5.25" H, and it weighs about 12 lbs. The ceramic feed-through threaded terminals are located on the bottom of the transformer. Like all of the Chicago and Stancor "Sealed in Steel" transformers, it is a flange mount.
The cosmetic condition is good, but it could benefit from a cleaning to remove the accumulated dust and dirt.
The price is $50.00, plus the cost of shipment to your QTH via FEDEX Ground from my zip code 11725.
Please feel free to ask me any questions about this unit; my e-mail is
triodes@optonline.netThanks & 73,
Bruce, W2XR
