But I did have some perfectly good 3/8" screws that would fit, so I decided to use one of those instead of the right screw, which I would have had to locate and purchase. What's 1/8" difference, right? Well, that 1/8" difference shorted the B+, which fried the rectifiers in the power supply, the 50 ohm 10W resistor from the rectifier bridge to ground, and the power supply choke. Doug, WB5IRI
Yep, at one time or another we all come across this situation in its various forms.
The worst version (though rare) is when one of the screws was designed to be a little longer than the rest and MUST go into a certain hole. If we just "shotgun" pull a rig apart, we will never notice it.
About six months ago, I pulled the cover off the bottom of my modulator chassis . I found two metal-screws threaded right thru an 8 uf, 1KV oil filled cap. I'd forgotten that I added this cap and did not mark the "no screws" holes.
It can happen in many, many different ways.
