April 22, 2025, 08:07:40 AM *
Author Topic: Watch out for 0 ohm restors  (Read 3992 times)
KF9CM
« on: February 28, 2014, 07:19:50 PM »
Now that I'm retired, I'm doing a lot of CNC work PCBs. They're single sided so I find myself using jumpers to make a few cross-overs. Most of the boards are RF type. I use Eagle Cad for my layout and I  opt to use wire. I thought I could use 0 ohm resistors until I checked them across my LCR meter.  It seems they read out at 88 nh. Now this probably doesn't mean much on HF, but I think this might be a problem in the VHF/UHF region.
73 de Gary, KF9CM
73 de Gary, KF9CM
www.kf9cm.com
« Reply #1 on: February 28, 2014, 08:14:15 PM »
  Gary,
    A piece of straight wire has inductance.
Look at this here:
http://www.ee.scu.edu/eefac/healy/indwire.html
  So I tried 3" of 24 awg into that formula, and it computes to 97 nh.
Take your setup and minimize the lead length. The inductance should drop down quite a bit. To measure that resistors inductance, you must have zero lead length, or a meter that can factor out the wires.
Wd5JKO
« Reply #2 on: February 28, 2014, 11:44:11 PM »
You have that much inductance in the curve on the wire.  Try putting the resistor directly across the binding posts, cut any extra lead length.  See what the reads, should see some change.
KF9CM
« Reply #3 on: March 01, 2014, 10:56:22 AM »
There's a straight wire (9nh) and the 0 ohm resistor (47nh) with short wire leads. I thought this might be of interest for guys working with RF PCBs.
Gary
73 de Gary, KF9CM
www.kf9cm.com
« Reply #4 on: March 01, 2014, 11:34:10 AM »
Gary,
Seems that reducing the lead length reduced the inductance by about half.  88nH to 47nH.
Thanks for posting this info, good to know.
KF9CM
« Reply #5 on: March 01, 2014, 11:49:41 AM »
Thanks Fred,
28pf across that 0 ohm resistor will put you about in middle of 2 meters.
Gary
73 de Gary, KF9CM
www.kf9cm.com
« Reply #6 on: March 01, 2014, 01:27:27 PM »
Gary,
What's the reason for using 0 ohm resistors??  Why not just a jumper wire??  I suspect that it's got something to do with production machines being able to better handle resistor bodies rather than pieces of wire.  Just a guess.
KF9CM
« Reply #7 on: March 01, 2014, 04:08:59 PM »
I think you're right on the pick and place machine. I picked them up for 25 cents for 100. I'll put them in a parts drawer and label them 0 ohm / 47nf choke Grin.
73 de Gary, KF9CM
73 de Gary, KF9CM
www.kf9cm.com
Page created in 0.157 seconds with 18 queries.
