April 24, 2024, 08:19:33 PM *
Author Topic: Adding 160 meter coverage to Drake 2A/2B  (Read 3645 times)
« on: August 13, 2013, 05:21:35 PM »
While browsing my Drake files for info about the Drake 2LF (low frequency converter for the 2A/2B receivers) I came across the Drake factory note for adding 160 meter coverage without using the 2LF.  It only requires 3 capacitors and a crystal and appears very simple to implement.  The Drake bulletin says it is only applicable to those receivers (presumably the 2A) with a serial number of 1,000 or higher.
I currently have a 2LF in my 2B but I may make this mod to my 2A so it will cover 160.
* 2BSUPPL.PDF (193.58 KB - downloaded 585 times.)
« Reply #1 on: August 13, 2013, 08:50:14 PM »
Thanks Rodger for that information.  I have a 2A and 2B and will have to check the SN on the 2A.   I usually use the 2B on CW with my novice DX-60 for SKN.  Great CW receiver but a bit narrow for AM.
Joe, GMS
« Reply #2 on: August 14, 2013, 08:26:20 AM »
I used to think that too Joe.
But now +\- 3kc is about my limit.  All my older kludge receivers sound alike.  Grin
« Reply #3 on: August 14, 2013, 08:38:22 AM »
Well you need one of those new fangle DSP hearing aids Rick!
Hey, there are worse problems  Wink
Joe, GMS
