April 24, 2024, 04:48:12 AM *
Author Topic: Large Plate Iron and Variac FS  (Read 2419 times)
W3FJJ
« on: July 04, 2013, 09:22:03 AM »
From left to right in picture
3 plate transformers
1.   4400v at about 3/4 amp?, (no center tap) 200v,215v, 220v 240v input taps, pulled from
     Henery 2000d , 3cx3000a7 Amplifier. Elec. corp of amaerica model eca-1028
     2000d was made to run at 4200v dc out, this  xfrm
     has two high voltage taps, I belleve it can run 5000v easily.
     I believe this is  same transformer Used in the Henery 8K ultra amplifier.   $150
2.   Stancor 52C046  5000v Center tap at 3/4 amp?, 120v pri,  I believe this hallicrafters
     Part number and was pulled from HT4/ BC610 transmitter  $75
3.   4800V (no center tap) at 3/4 amp? pri taps 208v, 230v, ,  $75
One Large Variac,  Power Stat type s780, 220v input, 0-270v out at 28 amps, Has a geared motor, that turns it slowly,
                   could then be easily remote controled!   $125
All these Items are pick up only, located in Newark DE 19713, not far from I 95 and DE/MD border..
W3FJJ
« Reply #1 on: July 24, 2013, 05:26:38 AM »
Transformers are no longer available. Thanks-Chuck
Page created in 0.065 seconds with 19 queries.
