April 19, 2024, 04:42:55 AM *
Author Topic: Optimum Turn-To-Turn Spacing for a Flat Wire Coil  (Read 4537 times)
aa5wg
« on: May 08, 2013, 08:12:08 AM »
Hi to all,
I read the optimum turn-to-turn spacing for a coil is about the diameter of the wire.
What about flat wire that is wound broadside to the coil form?
Thank you,
Chuck
« Reply #1 on: May 08, 2013, 10:29:37 AM »
The spacing should be no less than half the diameter, wider is better. Length to coil diameter is also important. Look at the B&W tanks plus various QRO amps using flat strap for 6-10-15M.
« Reply #2 on: May 08, 2013, 04:26:38 PM »
If T is thickness and W is the width dimension across the face of the wire, the minimum spacing is usually the W dimension.
aa5wg
« Reply #3 on: May 08, 2013, 05:10:12 PM »
What if the flat wire is 1/16 inch thick and 1/2 inch wide?
Chuck
« Reply #4 on: May 09, 2013, 09:44:28 AM »
Thickness doesnt matter.
Also asking the same question on several forums at the same time doesnt help.
aa5wg
« Reply #5 on: May 09, 2013, 07:49:26 PM »
Carl,
I agree about double post.  I must have been clicking the mouse to fast.
Chuck
