April 23, 2024, 07:19:09 AM *
Author Topic: Optimum Turn-To-Turn Spacing for a Flat Wire Coil  (Read 3480 times)
aa5wg
« on: May 07, 2013, 09:30:08 PM »
Hi to all,
Modified question:
New Question:
I read the optimum turn-to turn spacing for a coil is about the diameter of the wire.
What about flat wire that is wound broadside to the coil form?
Thank you,
Chuck
Old Question:
Is there any documentation, recommendations or rules of thumb that can advise how much air gap (spacing) is needed between coil turns to prevent high voltage arcing/breakdown between adjacent coil turns for a given high voltage, i.e.1000 volts, 2500 volts, 5000 volts, 7500 volts, etc.?
I read about air gap spacing recommendations to help prevent high voltage breakdown/arcing between air variable capacitor rotor and stator plates.
Are there similar recommendations for the output tank coil for the link antenna coupler?
This coil is going to be the tank output coil for the link antenna coupler.
Thank you,
Chuck
K5IIA
« Reply #1 on: May 07, 2013, 09:48:43 PM »
should be the same voltage all the way down the coil huh?
Be kind, for everyone you meet is fighting a hard battle.
73, Brandon K5iia
« Reply #2 on: May 07, 2013, 10:51:40 PM »
For a pure DC voltage, the voltage would be the same anywhere on the coil.  The same is not true for RF on the coil.  Hi Q coils can develop some very high RF voltages.
I've never seen any direct info on your question.  Spacing of the turns is largely determined by the amount of inductance required.
Hi-power circuits will generally use large coils.  Larger diameter coils have a greater amount of inductance per turn.  Based on that, the turns can be spaced a bit more for a given amount of inductance.
To try to answer your question,  look at the voltage ratings for tuning capacitors.  1/4" spacing is good for about 9KV peak.  A coil with 9KV across it would not need 1/4" spacing.  The coil has a certain amount of inductive reactance.  This reactance is distributed equally around the coil.  So, the voltage drop around the coil would be same for each turn.
So, if you had a 10 turn coil with 10KV across it, you would only have about 1KV between any two adjacent turns.  So, for 1KV the spacing can be close, off hand I forgot exactly what it is.  I think an ordinary BC tuning cap spacing is good for about 1KV.
So, in summation, if you have a coil with 1/4" spacing and you're getting flash over between turns,  you need to shut off all your equipment and take a break. Grin
aa5wg
« Reply #3 on: May 08, 2013, 05:12:13 PM »
Fred and all,
Thank you.
Chuck
