April 25, 2024, 01:33:43 AM *
Author Topic: Swap Even - My DSP 9024 6-band processor for your 528E  (Read 2509 times)
« on: December 26, 2012, 11:24:07 PM »
I am looking to swap even my Behringer DSP-9024 6-band  compressor/limiter processer, etc., for a Symetrix 528E.  (It must be the E model and work FB)
My DSP-9024 works FB.
Email me at:  K1jj@comcast.net
Tom, K1JJ
Here's a listing on eBay for a similar unit:
http://www.ebay.com/itm/Behringer-UltraDyne-DSP9024-AES-EBU-Digital-I-O-Option-/280644628550?pt=US_Signal_Processors_Rack_Effects&hash=item4157b93046
Product Information
The DSP 9024 offers six freely definable bands of dynamic processing plus a program-adaptive 3-band exciter, tube emulation and an integrated delay for “look-ahead” parameter adjustment. Interactive signal analysis and unique automatic functions enable you to get results fast, whether you need multiband compression, loudness maximization, de-essing or selective gating.
 •Digital stereo mainframe with two 24-bit high-speed signal processors
•High-quality Crystal 24-bit A/D and D/A converters for phenomenal audio quality and incredible dynamic range
•AES/EBU interface for digital connection (included)
•6-band compressor/limiter with gate and peak limiter
•3-band exciter with adjustable ratio of odd to even harmonics
•Tube simulation with selection of popular tube types
•ULTRAMIZER function for optimal output levels and signal density
•VIRTUOSO function for program-adaptive compression
•True RMS level detection
•100 user memory locations
•Open architecture for easy software updates
•Integrated delay of up to 600 msec. permits intelligent algorithms to "look ahead"
•Interactive, adaptive program analysis
•Large, high-resolution backlit LCD graphic display for outstanding readability
•Servo-balanced inputs and outputs with XLR and 1/4" TRS connectors
•Relay-controlled hard bypass switch with auto bypass function in case of power failures (safety relay)
•Firmware version 1.3
•Input power 115V AC
« Reply #1 on: December 27, 2012, 03:11:39 PM »
Found a Symetrix 528E.
The DSP 9024 6-band processor is now available for $250 + shipping.
