May 19, 2026, 12:30:16 AM *
Author Topic: Open Wire Spreader  (Read 31090 times)
aa5wg
« on: October 30, 2012, 09:31:04 PM »
Who has great home made open wire speader that works without glue, extra twisted wires, UV protective
and is mechanically sound?
At present I am leaning towards a single cable tie passing through the center of a 1/4 inch UV black pvc pipe that will hold the two wires tight by zipping the tie tight with a pair of pliers.
Thus far the head of the cable tie dose not bend easily to conform to the wire O.D.  I have a different type of cable tie on order to test.
I am not sure this will work any better.
Looking forward to hear and see pictures of your better ideas.
Chuck
K3YA
« Reply #1 on: October 30, 2012, 10:08:49 PM »
I can't meet all your requirements.  However the best spreaders that I ever came up with I made over 25 years ago and are still going strong.  Just survived a hurricane.
They are 1/2 hardwood dowel rod boiled in paraffin.  They need the twisted wires that you don't want.  The wood dowel is available in any hardware store.  The paraffin is wax toilet seals melted on a hot plate.  Melt the wax outside in case it catches fire!  Solder a small loop of wire to hold it in place.
It may be more work then you want to make but it will last forever and is very light weight.  Sorry about the blurry photo.
aa5wg
« Reply #2 on: October 31, 2012, 08:51:51 AM »
K3YA:
Thanks for the information on your spreader.  At one time I used spreaders like these.
However, I am looking for something that can eliminate the extra twisted wire that holds
the spreader in place.
Chuck
« Reply #3 on: October 31, 2012, 11:09:02 AM »
One problem with pipe or hollow spreaders is they get to fill up with conductive gunk and dirt over time.
aa5wg
« Reply #4 on: October 31, 2012, 12:34:31 PM »
DG:
Good point.
Chuck
« Reply #5 on: October 31, 2012, 01:52:46 PM »
I use 3/8 Lucite solid rod stock cut in 6" lengths.  Been up for 30 years without a problem.  Does use the tie wires like Charlies, K3YA spreaders.  I used 14 gauge solid copper magnet wire for the feeders which are 125' in length.  Feeds a 260' center fed up 60'.
Joe, W3GMS
aa5wg
« Reply #6 on: October 31, 2012, 02:22:09 PM »
HI Joe:
Thanks for your input.  Sounds like you have a nice antenna.
Chuck
« Reply #7 on: October 31, 2012, 02:24:03 PM »
I've seen plastic rod, cut to length, with the wire captured by heating it (the wire) up and 'melting' it into the ends of the rod.
W1AEX
Un-smug-a-licious
Apache Labs SDR
« Reply #8 on: October 31, 2012, 04:45:50 PM »
A number of people up here in the Northeast are using Fi-Shock electric fence insulators. I used a hot glue gun to fasten the feedline wires but someone more clever than me came up with a simpler method. The insulators are hollow, so they slide a long zip tie (11 inch zip tie works fine) through the center and then capture one of the feedline wires and double the zip tie back through the insulator. They then capture the other feedline wire and pull the zip tie tight with pliers. It's very secure, lightweight, offers little wind resistance, doesn't require re-tuning when wet, and it's UV resistant as long as you use UV resistant tie wraps. The Fi-Shock insulators are about 20 bucks per box of 200 at Tractor Supply outlets or when ordered online.
Rob W1AEX
« Reply #9 on: October 31, 2012, 05:01:18 PM »
A number of people up here in the Northeast are using Fi-Shock electric fence insulators. I used a hot glue gun to fasten the feedline wires but someone more clever than me came up with a simpler method. The insulators are hollow, so they slide a long zip tie through the center and then capture one of the feedline wires and double the zip tie back through the insulator. They then capture the other feedline wire and pull the zip tie tight with pliers. It's very secure, lightweight, offers little wind resistance, doesn't require re-tuning when wet, and it's UV resistant as long as you use UV resistant tie wraps. The Fi-Shock insulators are about 20 bucks per box of 200 at Tractor Supply outlets or when ordered online.
Rob W1AEX
I like the zip tie approach Rob.  Very clever with that method of holding the wire to the spreader.  I had never seen that one before.
Joe, GMS
W1AEX
Un-smug-a-licious
Apache Labs SDR
« Reply #10 on: October 31, 2012, 05:08:24 PM »
Hi Joe,
Yes, I wish I could take credit for it!  Smiley
I think Bob K1KBW or Blaine N1GTU came up with that one. If I ever have to re-do my feedline I will definitely do it that way.
Rob W1AEX
aa5wg
« Reply #11 on: November 01, 2012, 10:03:13 AM »
Hi Rob and all:
I was going to do exactly the same thing you did with the Fi-Shock except use small O.D. schedule  80 black UV pipe (.540 inches O.D. and .282 inches I.D.) that is rigid.
How rigid are those Fi-Shock 4 inch insulators?  Do they flex or bend?  Dose Fi-Shock make a non-ribbed smooth version?
Thank you.
Chuck
Detroit47
« Reply #12 on: November 01, 2012, 11:13:53 AM »
I like these I saw them at Dayton. http://www.73cnc.com/product_p/ls100.htm
John N8QPC
aa5wg
« Reply #13 on: November 01, 2012, 12:02:20 PM »
John:
Have you used the Ladder Snap speaders?  Their add states used with #14 wire.  Do you know if they can be used with larger diameter wire, i.e. #12 and #10?
Chuck
K6IC
« Reply #14 on: November 01, 2012, 12:55:29 PM »
AEX Rob,  your feedline looks very sporty!
Chuck,  OWL has very low loss,  as you know.  Why would you want to use larger guage wire than #14 AWG?   Is that just for durability?  Unless the antenna you are attaching the OWL to is center-supported,  #12 or #10  would be HEAVY.  Just opinions,   GL Vic
aa5wg
« Reply #15 on: November 01, 2012, 01:21:11 PM »
Vic:
I agree, any of these gauges would work.  Yes, the larger gauges are heavy.  Over the years I tried some heavier wire and it worked well at my station.  It seems I read an article talking about advantages of #10 for high power.
In the shed I have a pile of #10 and #8.  The #8 is VERY heavy but I have it.  I hate the idea of buying more wire at today prices.  Why not use the stuff I have laying around.  That is why I was asking about larger wire.
Chuck
W1AEX
Un-smug-a-licious
Apache Labs SDR
« Reply #16 on: November 01, 2012, 06:59:12 PM »
Chuck - I would describe the insulators as "stiff" but not rigid. If you pick one up you can flex it slightly but the ribs keep them straight. That being said, it's possible to bend one back onto itself with a little effort. With the same effort, you can then bend it back straight and it will re-assume it's straightness. The force required to bend them is far more than one of these would ever encounter in use as an open wire spreader. My feedline has been up in the air for close to 2 years and none of the spreaders show any signs of stress or deformation. I don't believe that Fi-Shock makes a non-ribbed version of the tubular insulators.
Vic - When my daughter-in-law first noticed the open wire line heading up into the sky she politely asked me, "What's the hamster ladder for?" I told her that there were lots of elderly squirrels in the woods and that it helped them to get up and down the trees. She giggled and hasn't asked any more questions about it but I can tell she thinks it's sporty too.
Rob W1AEX
aa5wg
« Reply #17 on: November 01, 2012, 10:22:40 PM »
Rob and all:
I went down to Tractor Supply and found the 4 inch ribbed tube insulators.  The salesman said Fi-Shock was sold to by Zareba.  I bought the last box of 200.  The box is now yellow and black with Zareba on it in stead of Fi-Shock.  The price was $12.99 plus sales tax.
I see what you mean by being a bit pliable but fairly strong.
When the cable ties show up from UPS I will give this a try.
Thank you.
Chuck
« Reply #18 on: November 01, 2012, 10:34:53 PM »
About 5 years ago I built 300' of 3/4" spaced open wire for 6M use.  It needed to be very low loss and close spaced to keep radiation to a minimum. It was intended to feed a fixed stack of 2el 6M Yagis.
To make the OWL, I bought about ten feet of white 1/4" Teflon rod. I cut it into 1" lengths and drilled holes in the ends. I slipped them thru #10 solid enameled wire. I used #16 wire to tie the teflon rods to the #10 openwire.
Worked like a charm on 6M.  Pretty lightweight too.  I shud take some pics of it and post here.
I finally ended up going with hardline and coax to feed the 6M Yagis, so have this FB openwire sitting around. Shud use it for something...
Detroit47
« Reply #19 on: November 02, 2012, 10:35:01 AM »
I checked out the samples at Dayton. And I liked them so I bought a bag that was labeled for 100 feet. I haven't used them yet. I currently am using True Laddder line with no regrets. http://www.trueladderline.com/ So I don't know about using a diffrent wire size, Send them an Email and ask them.
« Reply #20 on: November 02, 2012, 12:42:58 PM »
16 AWG stranded wire is plenty for any BC rig on OWL line.  GOing larger is not going to do anything but increase weight.  It runs ICE cold
Lots of neat ideas.
« Reply #21 on: November 02, 2012, 12:56:51 PM »
Lots of neat ideas.
A number of us do not have room for a half wave doublet. Wire gauge can become an issue when feeding low radiation resistances.
« Reply #22 on: November 02, 2012, 01:00:20 PM »
Good point!
W4NEQ
« Reply #23 on: November 02, 2012, 04:11:39 PM »
Although we might be getting into the area of diminishing returns, larger gauge certainly has lower loss, particularly at low impedances or with high circulating currents - not uncommon when operating the line well off its Zo.  I use #10 with 2 inch ceramic spreaders for a line impedance of about 440 ohms.
This well known graph shows loss for #12:
http://w4neq.com/img/arrl_loss_graph.jpg
Chris
« Reply #24 on: November 02, 2012, 07:58:29 PM »
If the antenna is not very short for the frequency, there will be no gain in going over 16 awg. The current is low, There is no heating of the line.  I can see where going past that might help on a very short line on 160 or 80.
Thousands of people including me use the available 600 ohm open wire line and that uses 16AWG.
