April 19, 2024, 12:09:03 PM *
Author Topic: Duty cycle for a Dow Key relay  (Read 16825 times)
« Reply #25 on: September 05, 2012, 10:14:08 AM »
Actually, some models of Dow-Key are not good for that application, as they have shorting contacts in them to ground the RX antenna lead on transmit. It is a small spring loaded fadiddlin in the NC side of relay. You can tell these type as they have a longer barrel on the RX antenner connector. They can be a little troublesome and would prolly wipe out the finals in a solid state rig if they didn't make (or break) properly.
As far as transmitter power that they will handle, I have used one with my 4X1 rig for many years.
« Reply #26 on: September 05, 2012, 07:38:55 PM »
Some dow keys smell like burnt band aids when overheated.
« Reply #27 on: September 05, 2012, 07:55:01 PM »
The HA-6 here had the original Dow Key inside when I bought it about 25 years ago and its still doing fine even with 2-4 hour VOX CW pileups.
The 1500W 2M amp uses a Dow Key transfer relay and has been abused as well in contests for over 25 years, same coil as the others.
Never had a failure in the AM days at the KW level either with long winded transmissions.
Ive read of several coil failures which I suspect is a manufacturing defect or RF got in.
« Reply #28 on: September 06, 2012, 01:52:16 PM »
lasts for ever as long as you don't wet switch the contacts.
I actually go for the mil relay with potted coil and N connectors. They are cheaper and built better. They also work well at 28VDC
