Now this is a Variac!
N0WEK:
I needed a variac to turn down the plate voltage on the Gates BC-1J and this one became available at a good price. I just didn't realize how heavy it was; 54 lb shipping weight!
Now I just need a really cool large spoked knob to turn it!
240 vac in/0-280 vac out @ 28 amps; more than twice what I need, but it'll keep the plate supply stiff!
Pete, WA2CWA:
When you post a picture with that high of resolution and size (over 4 megs), it will take forever for a slow DSL or dial-up to load if clicked on.
Mike/W8BAC:
Cool Greg. I used resistors and never thought of this. Good luck and have fun.
Mike
www.w8bac.com
N0WEK:
Quote from: Mike/W8BAC on August 03, 2012, 09:00:03 PM
Mike
www.w8bac.com
Mike,
I looked over your website and realized that I'd seen it before. I stole the idea of a 2x2 dummy to plan the move of the Gates into the basement; it cleared the side door by about 1/4 inch on either side and the top. I had to cut out the bottom step on the flight going to the second floor so I could turn the transmitter after I got it in the door. Same problem with finding a space between the joists to stand it up. I did add 4 heavy duty casters to the bottom plate such that the wheels only raise the cabinet off the floor about an inch. Mine was only about 300 lbs since I pulled all the units but the meter and relay panels and the wiring harness.
Hopefully I'll get the Gates on the air by next spring.
Greg
N0WEK:
Quote from: Pete, WA2CWA on August 03, 2012, 08:56:38 PM
Fixed that!
Navigation
[0] Message Index
[#] Next page
