Hi Jim! Your limiter is great.
http://amfone.net/Amforum/index.php?topic=22341.0You can see from the simulations.
With three voltage levels it is very progressive. As soon as the waveform goes near zero it becomes stronger and stronger, but never makes a flat clipping.
The simulations are the same circuit with a progressive reduction of the number of diodes. To find which waveform is associated to a circuit just see the name of the waveform, that reports the resistor to which it is related.
Well done Jim!
