I am starting to go through a Navigator I picked up and like many other Navigators the meter coil is open. Looking at the schematic the meter (10 ma movement) is either directly in series with the grid or is in parallel with a 33 ohm resistor for plate current measurement. The 33 ohm resistor is spot on and not switched so the meter should never have full plate current flowing through it.
I found a cosmetically matching meter movement that I will transfer the scale from and I will use a resistor to adjust the sensitivity to match. But I am not seeing any clear circuit reason why so many Navigator meters have failed. For example two were recently listed on ebay and both had replacement meters. I have not had a failed meter in any of my other Johnson rigs so either it is the movement (probably since it is a different type) or something I am missing in the circuit. The schematic is on edebris for anyone interested:
http://bama.edebris.com/manuals/johnson/navigatr/ and the schematic file is NAVFIGAD
This was a common problem on the Heathkit AT1. In that case, and possible this case too, any incidental contact to ground with either meter terminal when the meter is in the plate current mode will run B+ from the other meter terminal through the meter and it will go "puff". In the case of the AT1 it would often happen when someone was working on the rig with the power on.
Maybe - Mike
