K6JEK
Offline
RF in the shack
« on: January 24, 2012, 08:22:56 PM » |
I have an opportunity to acquire a used Crown 5000 for a bargain basement price. It's rated at 5000 watts into 4 ohms. What could I do with it? http://www.crownaudio.com/amp_htm/xls.htmPS Wow is it heavy.
Offline
« Reply #1 on: January 24, 2012, 09:11:41 PM » |
Offline
« Reply #2 on: January 24, 2012, 10:55:57 PM » |
You could use it with a pole pig reversed connected to power a Tesla coil modulated with music. Think of the Sparks dancing to the music. Do not use Rap music under penalty of law!!
W4AAB
Offline
« Reply #3 on: January 24, 2012, 11:00:16 PM » |
RAP= Retchedness Attempting Poetry.
W3LSN
Offline
« Reply #4 on: January 24, 2012, 11:21:12 PM » |
If the power bandwidth is adequate, you can get yourself one of those FCC Part-5 Experimental Licenses and make it your final PA on the 136 kHz VLF band. 73, Jim WA2AJM/3
Rob K2CU
Offline
« Reply #5 on: January 25, 2012, 09:23:10 AM » |
based upon the output voltages, you might be able to directly power/modulate a class E transmitter.
Offline
« Reply #6 on: January 25, 2012, 11:04:33 AM » |
Didn't you build a linear amp with multiple 4-125s?
Set it up for class C hi hi fb level mudulation.
Grab an Antek toroid xfmr. See Stu's excellent advice somewhere on here.
In 1993 I had a BC-610 with a 3-500z hacked into the final modulated by a Crest 4001. Used 1/2 of a T-368 plate xfmr for mod iron. (110/6336CT) Fed the B+ through a bunch of PS chokes in series.
It was JSed together just to see if it would work. Everything was in a very small shack.
The only guy I worked with that death trap was WB3HUZ. Wonder what ever happened to that guy.
Offline
« Reply #7 on: January 25, 2012, 11:36:02 AM » |
Pink Floyd
K6JEK
Offline
RF in the shack
« Reply #8 on: January 25, 2012, 02:46:11 PM » |
All excellent suggestions but I have to weigh the value of the application against the weight of the object, 75 pounds including power cord and dust.
I had been thinking of a modulator for a big class E but the Pink Floyd suggestion is intriguing. I stumbled on the speakers from the original Fillmore West in a warehouse out here. Hook em up and turn that baby on.
Money It's a gas Grab that cash with both hands and make a stash
7/8 or is it 7/4
I could combine the thoughts. Build a big Class E and play Pink Floyd on 3885, drive everyone nuts. Just kidding, just kidding.
Offline
« Reply #9 on: January 25, 2012, 02:58:13 PM » |
Hmmm, I have the perfect mod iron (7400W) but the cost of a step up transformer and shipping that beast would be a slight negative  Carl
K5WLF
« Reply #10 on: January 25, 2012, 03:00:58 PM » |
... I stumbled on the speakers from the original Fillmore West in a warehouse out here. Hook em up and turn that baby on. ...
Altec-Lansing A1-XXs X 4 (at least) if I recall. They had ladders up the front of them so the techs could service the multi-cellular HF horns. The only time I was in there, sitting (on the floor) against the back wall, where I could feel the bass and the music was right at threshold of pain -- there was a long-haired guy up one of the ladders with his head right up against one of the horns. He was into the music, took security about 15 minutes to get him down from there. I wonder if he could ever hear again.
Offline
« Reply #11 on: January 25, 2012, 03:08:31 PM » |
You might need a step-up transformer to make it work, but drive two deep ground rods as far apart as your property allows, then feed the audio between them. Supposedly some hams communicated by this method during the WWII shut-down. I recall an article about it titled "Radio through the ground". They claimed that with 20 watts or so, and good enough ground rods far enough apart, they could communicate over a mile away. The receiver consisted of two similar ground rods at the distant location, with headphones wired between them. If you could get several hundred feet of separation, and maybe use a couple of steel well casings to serve as the ground rods, 5 kw of audio might be audible tens of miles away. For the receiver, feed the output through an amplifier (with a good 60~/120~ filter at the input). Who knows how far you could work? Ground loops for miles around might pick up music intermodulated with 60~ hum. You might even achieve WALT (Worked All Landline Telephones).
Don, K4KYV AMI#5 Licensed since 1959 and not happy to be back on AM... Never got off AM in the first place.- - - This message was typed using the DVORAK keyboard layout. http://www.mwbrooks.com/dvorak
Offline
I QSY'd to QRZ
« Reply #12 on: January 25, 2012, 04:17:57 PM » |
You could use it as a spot welder and help Mike W8BAC with his battery project
Carl WA1KPD
Offline
« Reply #13 on: January 25, 2012, 04:43:21 PM » |
I can see all the worms and moles coming out of the ground now for miles around.
Detroit47
Offline
« Reply #14 on: January 25, 2012, 04:50:43 PM » |
Offline
« Reply #15 on: January 25, 2012, 05:49:42 PM » |
Set your audio gen to 60HZ. Wire up your Drill to the output of the amp and amaze your friends by drilling some holes with the drill. C
Offline
« Reply #16 on: January 25, 2012, 06:12:08 PM » |
I have a Crown M600. For audio it is good for 750W 1Khz @ 8 ohms or 1340W at 4 ohms. This was DC coupled, and rated for +/- 100V output at up to +/- 20 amps. It could be used like an op-amp. One application might be as a power supply for a Class E RF deck. Set the output at 40V to set the carrier level, and then modulate the DC reference input such that the AC swing would bring the peak output to 100v and that I believe would represent 150% positive modulation.
Maybe this newer 5K Crown is also DC coupled, and has higher +/- DC voltage capability than my M600 does.
Jim WD5JKO
k6jca
« Reply #17 on: January 25, 2012, 10:01:45 PM » |
I saw something similar to this in Electronic Design (or was it EDN?) years ago. It goes like this... 1. Connect a signal generator to the input of amplifier (I think the original design used a 555). 2. Connect the output to mechanical transducer driven into the ground. 3. Turn on generator and lower frequency to the Earth's resonant frequency. 4. Apply signal until Earth is destroyed. Surprisingly straightforward. I'm surprised it hasn't already been done. - Jeff, k6jca
Offline
« Reply #18 on: January 25, 2012, 10:31:37 PM » |
"there was a long-haired guy up one of the ladders with his head right up against one of the horns."
Moth to the flame.
Offline
« Reply #19 on: January 26, 2012, 10:06:27 AM » |
Bridged it alleges 5kw into 4 ohms... But it is really a 1.1kW amp each channel into 8 ohms. Still not bad power. But I seem to recall that these newer Crown amps have a bad habit of letting the magic smoke out. I can check with a group of about a hundred top pro repair guys if ur interested to know for sure. But it's a nice amp, at 75lbs, not too bad... If it's not too expensive, I'd get it... its use will become apparent over time. You can run ur speakers with it, it won't clip...  (actually that makes an audible difference) _-_-bear
Offline
« Reply #20 on: January 26, 2012, 05:02:09 PM » |
« Reply #21 on: January 26, 2012, 05:37:28 PM » |
"there was a long-haired guy retard up one of the ladders with his head right up against one of the horns."
There, fixed it.
K5WLF
« Reply #22 on: January 26, 2012, 08:58:21 PM » |
There, fixed it.
It all seemed pretty retarded to me. I grew up a country music guy and still am. In high school I wore cowboy boots and pearl-snap shirts when the rest of the guys were wearing Beatle boots and Nehru jackets. I ended up at the Fillmore because one of my college friends wanted to check it out. Left to my own devices, I'd have been at a country bar. Best part of the whole evening was the Altec A1-XXs. I'd never seen a set of them in person before.
Offline
« Reply #23 on: January 26, 2012, 09:54:59 PM » |
hello test ....w3duq upside down amp POWERED by a crown 5000 amp ..... watch the lights dim ......
O would some power the gift give us to see ourselves as others see us. It would from many blunders free us. Robert Burns
Offline
« Reply #24 on: January 26, 2012, 11:22:31 PM » |
