coiling foam dialectric coax
December 11, 2019, 04:11:58 PM *
Author Topic: coiling foam dialectric coax  (Read 1420 times)
K6JEK
RF in the shack
« on: October 18, 2011, 11:56:07 PM »
I  have always avoided making coax coil choke baluns with foam dielectric coax.  I think I read somewhere the center conductor will migrate.
Am I right about this or can I actually coil up the LMR-400 ultraflex I got my hands on at the feed point of the hexbeam?
N8ETQ
Mort
« Reply #1 on: October 19, 2011, 05:04:21 AM »
     It's true, The term I heard was "Cold Flow". There should be a
"Minimum Bend Radius" specified that if not exceeded it wont
happen.  Your mileage may vary.
GL
/Dan
« Reply #2 on: October 19, 2011, 08:46:06 AM »
I used it in my first 4-1000A rig. It migrated and shorted.
« Reply #3 on: October 19, 2011, 09:21:40 AM »
Normally the bend ratio is ten times the diameter of the wire.  I would not use foam coax for this purpose.
K6JEK
RF in the shack
« Reply #4 on: October 19, 2011, 12:03:24 PM »
Thanks, guys.
« Reply #5 on: October 19, 2011, 06:20:32 PM »
I agree with the comments and recommendations. Still if the coax is out of the sun, exceptions to the rules can work. I have a 10' piece of Radio Shack RG-8X from the shack to the base of the antenna where I have a shorting knife switch. I take that coax 1' from the knife switch, and wound 6 turns through a 2" OD ferrite toroid to make a common mode choke. After about 3 years it is still working, and I've at times ran legal limit power with non-perfect SWR. Oh, antenna got a direct hit by lightning too, and vaporized part of my feedline to the knife switch. That tight radius turning around the 'roid' has yet to fail.  Wink
my 2 ¢,
Page created in 0.047 seconds with 18 queries.
