January 19, 2026, 08:44:02 AM *
Pages: 1 ... 3 [4] 5 6   Go Down
Author Topic: 40 meters early mornings in Europe  (Read 188247 times)
pe1mph
pe1mph AM from Holland
« Reply #75 on: July 10, 2011, 04:00:14 PM »
OK, Henk,
7.220 it is. Perfectly fine with me. Same time schedule as I am limited on other evenings this week. I am retired but work now more than ever. :-).
John, AA5T
Deal John!
I try! listening every morning between 06.15 - 06.50 hour (by me)!
Maybe you can get more AM stations on +/- 7220 khz. who call?!
Perhaps a 'little-pe1mph' AM net? Grin
When I hear a station, I put info in this Item.
Good transmission,
pe1mph / Henk
Dokkum / The Netherlands
AA5T
« Reply #76 on: July 10, 2011, 06:39:49 PM »
OK, Henk,
6:15 to 6:45 your time. 7.220, Of course, by posting this frequency and time
here on AMFone, anyone is invited to join in. If you can hear us on 7.220 +/-
then we will figure out a good spot for you to transmit. With patience we will
together work it out.
John
pe1mph
« Reply #77 on: July 11, 2011, 12:45:49 PM »
OK, Henk,
John
Only receiving John!
I listen only before I go to work....
And, you know, I (we) may not transmit on 7220 khz. Grin
Good transmission, Henk
AA5T
« Reply #78 on: July 11, 2011, 01:04:44 PM »
Hi Henk,
Yes I know that you cannot transmit on 7.220. Reply by posting onto
AMfone.net. I will look there.
John
ve6pg
« Reply #79 on: July 13, 2011, 12:22:11 AM »
john..tim here, ve6pg, hanover, ontario..i'm hearing you, not too strong, but lots of ssb qrm..
..tim..
..sk..
AA5T
« Reply #80 on: July 13, 2011, 12:52:00 AM »
Hi Tim,
Thanks nice to hear from you. You are a little off the directivity of my antenna.
I use a 3 element vertical parasitic array aimed at Europe. 6DB gain.
Why don't we join forces another evening. With 2 of us calling we stand a better
chance of being heard. I have contacted another EU AMer, that wants to join in.
His call F6AQK, his name Jean.
In any event let's, chat on the band one day.
John
P.S. As you say plenty of QRM around 7.220 this evening.
pe1mph
« Reply #81 on: July 13, 2011, 09:35:57 AM »
The results, this morning!
I listen between 06.15 - 06.45 hour by me.
My receiver Kenwood R 5000.
Ant. +/- 45 mtrs wire, connect with ant. tuner to receiver.
- 7225 KC?? station in ssb often on air early mornings
- 7208 K8?? station in ssb talking with a mobile station
- 7220 K4?? station calling often CQ, very good to hear!
I am 100% sure there were on 7220 khz AM stations on air!!!
But signals to weak for me to hear audio in AM mode...
Therefore I need to listen in ssb mode....
Freq. between 7215 - 7225 were this morning totaly free from BC-stations.
So you (AM Lovers) can use these freq. between 06.15 - 06.45 for Europe...
I listen next days again on above freq. (7215 - 7225 khz). Grin
Maybe conditions were bad today?
When I listen, its raining in Holland.
Good transmissions,
pe1mph / Henk
AA5T
« Reply #82 on: July 13, 2011, 10:25:11 AM »
Hi Henk,
OK you heard me calling CQ on 7220. I alternated between calling you and CQ.
I transmitted at 0500 GMT+2 and 0600 to 0625 GMT +2. That is an OK start.
I will not be on again until next Tuesday due to business. Perhaps Tim, VE6PG
would make a schedule with you. Post a mesage here on AMFONE.net for him.
John
ve6pg
« Reply #83 on: July 13, 2011, 11:00:51 AM »
..called cq this morning, 7220 at abt. 1am eastern...no takers....this weekend i have to finish repairs to my 40m vert. at present, using a viking 2 cc, sx101 and 160m loop with owl, at 70 feet...the vertical does well, so that might be the trick...been active on 7220 most mornings, as i get home from work around midnight...
..tim..
..sk..
pe1mph
« Reply #84 on: July 13, 2011, 01:22:39 PM »
Hi Henk,
John
You call K4?Huh
If thats you I heard mention sometimes CQ!
Then  I heard you loud & clear on 7220.
Greetings, PE1MPH
AA5T
« Reply #85 on: July 13, 2011, 02:20:57 PM »
Hi Henk,
Some confusion here. I did not give a K, call, I gave AA5T. However, I was calling
CQ,CQ. There were SSB stations above and below 7.220. I was between them.
I did call you PE1MPH many times. It could have been a K station that I did not hear.
We will probably never know for sure.
I will try again next Tuesday.
John
AA5T
« Reply #86 on: July 14, 2011, 08:57:48 AM »
Hi Henk,
If you listened on SSB you must have heard the AM carrier. The audio might
be missing but the carrier should have been heard at 350 watts.
John
ve6pg
« Reply #87 on: July 14, 2011, 12:05:04 PM »
..i was on 7220 this morn, at 1am w/carl, kb3rdt..condx not bad...b'cast station came on at 1:45 am, so we both shut down...there were other carries, and someone called me during carl's tx, but he did not return...will try agn tonight..
..tim..
..sk..
pe1mph
« Reply #88 on: July 14, 2011, 01:07:10 PM »
..tim..
..sk..
This morning I heard only 2 ssb stations on 7215, mention Ohio?
But I listen every morning between 06.15 - 06.45 on 40 mtrs.
Good dx, pe1mph, Henk
pe1mph
« Reply #89 on: July 17, 2011, 12:31:14 AM »
Hello.
Now on 7180 in AM:
F6AQK
PE1BIW
9H1ES
I made recording from Jean (F6AQK) on 7180 khz.
Next week (mornings by me) I monitor again on +/- 7220! Grin
Greetings,
pe1mph / Henk
Dokkum
* f6aqk 7180.mp3 (1574.46 KB - downloaded 824 times.)
pe1mph
« Reply #90 on: July 21, 2011, 01:15:38 PM »
Hello AM Lovers,
Last days I heard totaly nothing around 7220 in AM!
You know I listen mornings between 06.15 - 06.45 hour by me!
Between 7220 - 7225 khz is (mostly) free.
And on 7215 khz I hear sometimes a carrier, without audio.
Maybe next days I can hear am.....?
Greetings,
pe1mph / Henk
AA5T
« Reply #91 on: July 22, 2011, 09:43:24 AM »
Hi Henk,
I have been out of town but am now back. I will be on 7.220 tonight Friday,
22 July. 11:15 to 11:45 PM Central Daylight Time. You are GMT + 2.
0615 to 0645 AM Saturday morning.
You can reply on AMFONE if you hear me. Otherwise let me know what
frequency you will transmit on so that I can listen for you.
John, AA5T
pe1mph
« Reply #92 on: July 22, 2011, 12:40:55 PM »
Hi Henk, I have been out of town but am now back. I will be on 7.220 tonight Friday, 22 July. 11:15 to 11:45 PM Central Daylight Time. You are GMT + 2.
73, John, AA5T
This morning I listen between 06.00 - 06.50 hour (by me!).
I am 100% sure I heard +/- 06.05 a station calling: CQ, CQ, CQ on 7220 khz.
Sorry the station mention his call to fast for me to understand it correct!
And between +/- 06.35 - 06.45 I could hear 2 stations in AM.
But conditions dropping down, not possible to understand who speaking.
Later I received a 'naked weak' carrier on 7220, without audio.
Greetings, Henk / PE1MPH
Ralph W3GL
« Reply #93 on: July 22, 2011, 03:12:32 PM »
   I was on calling CQ at that time Henk... What I spoke was
   "CQ CQ CQ, Seeking You on 7220 in the AM mode" and made
   multiple transmissions from 0400 to  0415 GMT...
    At about 0420 or so I heard a carrier appear on frequency and
    had a 15 minute chat with Carl, KB3RDT in North West Pennsylvania.
     He was running 100 watts to a dipole at 30 meters high and my out-
     put was about 350 watts to the 200' Center Fed Zepp at 30 meters
     high.
73,  Ralph  W3GL
kb3rdt
poop cup
« Reply #94 on: July 23, 2011, 12:33:57 AM »
hello i heard aa5t calling cq and i fired up then got a phone call i am bout to call cq at 12:35 eastern time
ve6pg
« Reply #95 on: July 23, 2011, 12:40:06 AM »
..john..tim here...hearing you here, in ve3...band is quiet, but u r not too strong here...i give a call in a few minutes...
..sk..
AA5T
« Reply #96 on: July 23, 2011, 01:02:43 AM »
Hi Tim,
Great to chat with you on 40M AM. I am having some trouble with my AM amp.
Seems as soon as it gets hot it has a problem. I will replace  it with a backup amp.
I usually use my Globe King but don't have crystals for 7.220.
Seems you are in VE3 land. I used to work in Detroit and have visited most of VE3 land. Did not receive any reply from the guys in EU.
Thanks for the call.
John, AA5T
ve6pg
« Reply #97 on: July 23, 2011, 01:12:31 AM »
..no john, just heard you..i'm a little surprised more are not getting on 40...band seems in good shape, not much noise...i'm hearing ssb guys around n.america, so propagation seems ok...just keep trying, i guess..
..tim..
..sk..
pe1mph
« Reply #98 on: July 23, 2011, 03:35:51 AM »
I was on calling CQ at that time Henk... What I spoke was "CQ CQ CQ, Seeking You on 7220 in the AM mode" and made multiple transmissions from 0400 to  0415 GMT...
At about 0420 or so I heard a carrier appear on frequency and had a 15 minute chat with Carl, KB3RDT in North West Pennsylvania.
Nice to hear you calling, no problem to hear the words: CQ, CQ.... Grin
Then I heard you later on 7220 again with another station?
But then very difficult to copy, maybe conditions were 'worse' then before?
This morning (Saturday by me) I heard totaly nothing around 7220 khz.
The BC station on 7180 khz were good to copy (S2 - S6), but I could not understand it.
Sounding like Asia or China language?
Tomorrow (Sundaymorning), just after 06.00 hours, F6AQK will be on 40 mtrs.
Perhaps around 7185 khz, ofcourse in AM, calling.
pe1mph
« Reply #99 on: July 24, 2011, 12:14:13 AM »
NOW!
On 7170:
F6AQK
PE1BIW
PE1MPH
Greetings,
Henk
Pages: 1 ... 3 [4] 5 6   Go Up
