April 25, 2024, 04:20:47 PM *
Pages: 1 2 [3]   Go Down
Author Topic: 5 minute ON, 2 hour OFF oil furnace timer to prevent freezing pipes  (Read 30186 times)
« Reply #50 on: December 17, 2010, 09:36:29 AM »
Tom,
All you need is a cheap thermostat. Just put the contacts in series with the relay coil.
« Reply #51 on: December 17, 2010, 11:18:14 AM »
Tom,
Yep, you're right, Frank. Why didn't I think of that?
The spare one I have here is a standard room thermostat and goes down to only 50 degrees, so will have to take a look on the web for something that works below 30F.
I think most are 24VAC too, so will have to find a 120VAC version to handle the timer circuit or add a second buffer relay.
I'm finding that 5 minutes every hour turn-on rate is too often. The pipes stay warm longer when down around 15F outside. So I will try 3 minutes every 1.5 hours for now.
« Reply #52 on: December 17, 2010, 04:24:20 PM »
I think you can still buy high voltage thermostats. they have larger contacts. A LV unit may work since the current is low.
Pages: 1 2 [3]   Go Up
