April 19, 2024, 02:04:41 AM *
Author Topic: 2-3 kV Plate Transformer  (Read 4072 times)
« on: November 08, 2010, 09:52:15 PM »
** This is a perfect transformer for a 500 Watt, plate modulated rig (e.g. the Tesla two 813s modulating two 813s). If you are going the linear amp route, this transformer is good for a legal limit amp using tubes up to 3 kV on the plates. **
I have a Stancor 52B046 high voltage transformer designed for 110 VAC input. The secondary is center-tapped. With 125 VAC input I get the following on the secondary (HV-to-CT)
Primary Connection Marked 2000: 2525 Volts
Primary Connection Marked 2500: 3050 Volts
This thing was designed to produce either 2500 or 2000 volts when used with a choke input supply. It appears to be BC-610 plate iron. It weighs 105 pounds and is approximately 12.5" x 8" x 11.
This thing is too heavy to ship. Come and get it. I can deliver or meet you in and around the mid-Atlantic, if you really need this thing. The next fest I will be attending is Richmond, VA in February 2011.
$100
Page created in 0.029 seconds with 16 queries.
