April 25, 2024, 05:44:03 AM *
Pages: 1 ... 3 [4]   Go Down
Author Topic: @&##$% wasps  (Read 38100 times)
N0WVA
« Reply #75 on: August 30, 2010, 09:02:36 AM »
Ive run across stinging nettle in many places here in the Ozarks, always along a creek or river. Maybe Im giving it an incorrect name, but there was a bulletin board at a camp site I read a long time ago that called it that, so thats what Ive been calling it all along. Closest to describing is imagine you worked up a good sweat and then you took some of that white powdery dry acid that forms over your battery connectors on a car or truck. Now rub that in and maybe that would be half as bad. But the nettle also itches and when you start scratching, the burn intensifies. If you happen to contact this stuff the only relief is jumping in the water and washing it off.
Interesting note on the handling of the plant.
 While we are on the subject of plants, there is one that I could never find a name for , but it has a bunch of little leaves in a row in each stem like a fern. And you can touch the leaves and they will "close up" .
« Reply #76 on: August 30, 2010, 06:58:08 PM »
Isn't that a vermosa bush?
« Reply #77 on: August 30, 2010, 10:59:42 PM »
The Venus Fly Trap does that too.
KX5JT
John-O-Phonic
« Reply #78 on: August 30, 2010, 11:14:31 PM »
The "sensitive plant" does that as do some other related mimosa and acacias.
Mimosa pudica... cool video shows the action
http://www.youtube.com/watch?v=Zq3UuHlPLQU
73, John
AMI#1684
« Reply #79 on: August 31, 2010, 12:53:56 AM »
N0WVA
« Reply #80 on: August 31, 2010, 08:04:51 AM »
73, John
Yeah, that looks like it. The wild ones aorund here have thinner leaves, but they do the same thing.
« Reply #81 on: August 31, 2010, 03:48:51 PM »
Wrong Killer Bee!
« Reply #82 on: September 01, 2010, 11:39:00 PM »
We use pyrethrin
http://www.bugspray.com/article/wasp.html
The key is to spray the nest if you can find it when its small.  I had half a dozen nests this year. Mostly small.  couple sprays, They cant fly anymore. That stuff is an oil base and it weighs them down.
« Reply #83 on: September 02, 2010, 11:12:09 AM »
We use pyrethrin
That stuff wouldn't be good to use while prepping for a paint job. You don't want to leave any kind of oily residue on wood or any other surface that is about to be painted.  Same goes for fighting them with WD-40.
« Reply #84 on: September 02, 2010, 12:25:24 PM »
If you use the red can Brakelean, it leaves absolutely no residue!!
The solvent in it that is is so deadly to them is a "defatting agent"
Hmmmm............... Maybe I should spray some on my mid section  Grin  Grin
Pages: 1 ... 3 [4]   Go Up
