Sorry Phil, but before someone gets killed I want to give my opinion -- this is an insanely bad idea. If you did this where I work you'd get fired in a second. The home should be no different. If the cover restricts ventilation, do what I did -- cut a hole in the top over the tubes with a jigsaw, metal tooth blade, and bolt down some expansion steel over the hole. If the cover is steel use cutting oil.
I too am concerned over HV safety, but before everyone gets overly excited (no pun intended),
there are
two top covers or panels on the Henry; both being perforated. (At least that is how my Henry is configured). And it appears to be the same pedestal type 2K-4 as mine.
The top cover covers the whole top rectangle including the RF deck and front panel area, and then there is the RF deck cover directly below it, shielding the operator from direct contact with HV components.
The RF deck perforated cover presses against a HV switch such that when this cover is removed, the HV is shorted, providing an interlock capability.
What I found was the RF deck will run much cooler if the "TOP" panel is removed, but still keeping with the RF deck cover, and this provides a measure of safety against HV accidental contact. The top cover, although being perforated itself, DOES restrict air flow.
Now one could install higher flow fans or whatever method that will improve cooling as well, and those would not be off the table by any means.
