you mean to say that the total 28.3v will be the average ac value and the 4 ohm is the nominal impedance of 2x100 8 ohm loudspeaker?
No. The 28.3v figure is the rms voltage. If you are talking about sine wave tones, the average value will be 0.9 X rms, or 25.5 volts, integrated over a half-cycle. If you integrate over the entire ac cycle, the average voltage is zero.
Average power = rms voltage X rms current
so, I can calculate now the rms voltage of the transformer based on the Vav of loudspeaker.
Unless you are dealing with sinewave tones, it is impossible to calculate, since the waveform of music and voice is completely unpredictable.
This might clear up some of the confusion regarding average power, average voltage/current and rms voltage/current.
