Globe King 500 help
April 25, 2018, 02:24:00 PM *
Author Topic: Globe King 500 help  (Read 7689 times)
K8WBL
« on: May 25, 2009, 10:52:06 PM »
OK, rebuilding the power supply on a Globe King 500A that was stripped out ...does anyone out there have a pic of the bottom of the chasis on the power supply portion of this transmitter?   Thanks..
73, Tim  K8WBL
K8WBL@yahoo.com
« Reply #1 on: May 26, 2009, 01:24:59 AM »
How close is the A to the C?  .. I just dont know if I Can help. Never owned the A model.
K8WBL
« Reply #2 on: May 26, 2009, 09:18:09 AM »
Not much difference at all I think.
Tim
K8WBL
« Reply #3 on: May 26, 2009, 09:19:31 AM »
The C has the VFO but I think all of the major power supply compoents are the same.
Tim
« Reply #4 on: May 26, 2009, 01:25:35 PM »
will this help?
K8WBL
« Reply #5 on: May 26, 2009, 01:53:23 PM »
Well, it helps a little, but what I really need is where the parts placements are ... dropping resistor, etc. and general running of cabling, etc.   The chasis I have is from a 500 series but a lot things have been removed.  I have an RF deck that has been unmolested and start rebuilding this transmitter as well as 2 a mod deck from a GK400C.
Thanks,
73, Tim K8WBL
« Reply #6 on: May 26, 2009, 04:18:11 PM »
Ok.   Mine is a 500C and the layout is very different as I have the large VFO sitting in the middle of the chassis. I will ask around to see if anyone I know owns a 500A.  I talk to 4 or 5 people on Kings.
Clark
K8WBL
« Reply #7 on: May 26, 2009, 05:38:43 PM »
Thanks Clark, I really appreciate that..mine is a 500A, so any version before the VFO addition is likely similar.
73, Tim K8WBL
kc2ifr
« Reply #8 on: May 26, 2009, 05:57:30 PM »
I find it amazing that no one has posted ANYTHING about the 500 on Bama.
Bill
K8WBL
« Reply #9 on: May 26, 2009, 06:07:07 PM »
Yeah, its pretty hard finding good info on the Globe King 400's or 500's anywhere, this list has been the best place to get info as well as the Midwest Classic AM net on 3885 Saturday mornings in the midwest.
72, Tim K8WBL
« Reply #10 on: May 26, 2009, 07:09:17 PM »
I agree. Thats why I made the 500 Document after I got mine up and running.  Without this list I would never have finished mine.
Clark
« Reply #11 on: May 26, 2009, 07:23:09 PM »
The manuals for all three of the GK 500 series are on BAMA.  There is a WRL list on QTH mailing lists if you care to join.  It is pretty inactive but there are people there who don't subscribe here.  Someone over there may have a picture but I doubt it.
I have a 500A but getting the power supply out to take a picture is much of a chore.  The layout of the parts is pretty self explanatory and all the wires run around the outside of the chassis.  I do hope you have the spacer for the tube sockets.
K8WBL
« Reply #12 on: May 26, 2009, 08:54:56 PM »
Thanks, thats a great idea.  I do have the spacers but will also use plug in SS rectifiers, been easy to get and cheaper than usual lately, Surplus Sales has then for something like $65 each...wow.  Also want this baby to look as original as possible, not a purist at all, believe me, functional!!  But would like to keep the integrity of the Globe King and don't want it to look like a re-do job, even though it mostly is, want it to look stock, as well as interchangable.
Don't hurt your back on removing it...its not worth that, I just thought someone might have a pic of one they put back together.
73, Tim K8WBL
w4fms
« Reply #13 on: May 26, 2009, 09:25:01 PM »
Tim...here's the underside of my 500C deck.  Hope this helps.
Frank, W4FMS
« Reply #14 on: May 26, 2009, 10:21:48 PM »
did some work on the picture to see more detail.
K8WBL
« Reply #15 on: May 26, 2009, 11:22:21 PM »
Wow Frank, thanks, that helps quite a bit, lots of similarities but lots of differences too, as expected with the VFO added.  The primary of the HV power supply is at the base of the pics, by the relays?  I think thats I see it.  thanks for all the work and effort on this Frank, its really appreciated!!  This gives me a basis.  There are lots of changes and the chasis was punched out definitely differently, but they kept alot of the same wiring harness to most of the major compoenants intact, added a transformer or two, filaments I suppose and other.
Regards, Tim
K8WBL
W8UJX
« Reply #16 on: May 27, 2009, 10:04:03 AM »
Hi Tim,
Here are some fotos of my 500A power supply.  If you need more help let me know.
http://www.qsl.net/w8ujx/GK%20500A%20PS/
Jerry/W8UJX/CA
K8WBL
« Reply #17 on: May 27, 2009, 03:34:19 PM »
SWEET....this is exactly what I need, to see and work with...thanks soooo much..what a great guy and group we have here...
73, Tim K8WBL
« Reply #18 on: May 27, 2009, 05:11:02 PM »
Just a note that you probably already know..  My 500C had 4UF on the HV supply.  I got a 10 UF cap and replaced it. I saw HUGE gains in overall performance. The rig gained alot of RMS when speaking and really cleared up the pattern.  I dont see that large cap at all in teh 500A. The transformer looks the same though. I wonder what the total is on the HV supply?
Clark
W8UJX
« Reply #19 on: May 27, 2009, 07:48:10 PM »
Hi CLark,
My 500A power supply is stock.  It has two 6 UF, 1500 volt caps in series
for a total of 3 UF at 3000 volts in the HV supply.  I agree.  A bigger cap would
give much better performance.
If I was rebuilding the power supply I would try to go with 10 UF as you suggest.
Jerry/W8UJX/CA
« Reply #20 on: May 27, 2009, 08:31:06 PM »
YEah.. Thats what I figured.. I saw the two caps sitting next to each other.. Plenty of room for a 12UF!
I was talking to Timtron one night and he said I needed to change that cap out.. He suggested 14 UF. Then someone on the board here suggested the same.  At a Ham fest, I found a 10UF at 3kv.  It bolted right in.  Better then the old 4uf cap.
The difference was dramatic enough that I had to recalibrate the scope. I was shooting right off the picture tube.
I also upgraded the one in the Mod decks power supply.  I think that one has a 6 or 8. I cant remember.. I got it from Robert W0VMC.  With the solid state Rectifiers, My mod volts on the 811s is up around 1560.
Clark
K8WBL
« Reply #21 on: May 27, 2009, 10:30:32 PM »
jerry, there are some significant differences in yours and mine, I have 4 toggle switches on the front panel, yours has only 3 toggles...I have a high B+ and Lo B+ switch as well as xmit, exciter and filament.  Other changes as well, interesting.  My RF deck is marked 500A and Number 845 on the top of the RF deck.
Tim
K8WBL
W8UJX
« Reply #22 on: May 28, 2009, 11:00:32 PM »
Hi Tim,
I have been working on an old GK 500C.  It was in very bad shape.  Lots of rust and broken parts on all the decks.  I wound up removing all parts from each chassis, cleaning the chassis and reinstalling the parts.
During this process I corresponded with Frank, W4FMS as he was doing the same thing.
Even though our rigs were the same model, 500C, we both found errors on the schematics in all three decks and differences in the hardware.
I found the mounting holes in the chassis were oversize and not deburred in many cases.  I got the impression that WRL used whatever components they had on hand at the time to complete a production run.
I have both a 500A and 500C and in both rigs the HV cap in the modulator is rated at 1000 VDC and the HV on the modulator tubes measures 1000 VDC.  Not good!
It was an interesting and educational project.
Jerry/W8UJX/CA
« Reply #23 on: May 29, 2009, 12:42:13 AM »
Yes.. That is normal.. WRL was a cheaper line of gear made for the avg joe. They had finance plans advertised with weekly cost.  I have a stack of old magazines from the 20s through the 60s and you could see adds for each model.
The old story was that Leo purchased alot of surpluss parts in bulk. They used the parts where ever they could. Mind had some serious errors in the schematic. One of which was the push to talk system. This system was never used in my rig because it never worked.  The cap that was installed with the rectifier was the wrong value and the relay would just chatter. You could see this was the original cap. The guys on the forum helped me trouble shoot it. Now the system works. I wired a switch up by the table so I can kick the unit on with a flip of a switch without bending down to the manual key switch.
My modulator deck was an odd ball with a very odd power transformer. It has 11 wires comming out of it and only 8 being used. It was fried as someone installed the wrong modulator tubes in that deck. Some had a 500V supply in the deck and others used a dropping resistor to get the LV for the mic pre tubes. Mine had the 500V supply off a resistor. Others had a tap on the transformer.  IN the end, I ran another HV lead from the power supplys 500V section up to the Mod deck. This took the draw off the weak mod power trans and put it down on the heavy PS decks supply. This allowed me to solid state the mod deck and get 1550 volts on the 811s. Something that really really helped my 500 come to life. The stock mod deck is weak at best.
They are neat old rigs and I sure love mine. Its been working now for 4 months on 75 meters.
Clark
K8WBL
« Reply #24 on: May 29, 2009, 08:31:08 AM »
Thanks Jerry and Clark, I have heard the same... I went through a bunch of similar stuff getting my GK400B working, the mod deck was different on every schematic I could find.  My 400B has a pair of 6V6's with a total of 4 tubes in the speech circuit, whereas the 400C I have has a single 6F6 in the final but an extra tube mounted in the middle of the 4 tubes on the mod-speech section.  The 400B has been modified before I got it, Couplates removed, etc,. The 400C does not, and the 500A does not have mod deck at all, will have to build that or use the 400's mod deck until then
73, and thanks all...still finding new stuff.
Tim  K8WBL
