December 02, 2025, 03:52:02 AM *
Author Topic: VIKING2 R30 CLAMP ADJUSTMENT..  (Read 2977 times)
ve6pg
« on: April 14, 2009, 12:21:07 PM »
..hi from tim...'been werking on my viker, and was wondering the procedure for adjustments to the chassis mount pot. i believe it to be, R30, 1MEG...ideas?
..sk..
W7SOE
« Reply #1 on: April 14, 2009, 12:53:08 PM »
Hi Tim,
   That is the clamper tube adjustment as described in the manual:
http://bama.edebris.com/manuals/johnson/viking2/
Making that adjustment involves adjusting r13 a ww adjustable resistor, be careful s the windings are fragile and may be tired from many years of HOT operation.
Rich
ve6pg
« Reply #2 on: April 23, 2009, 01:51:44 PM »
..ok...i adjusted the resistor for modulation resting current...but now, during a transmission, the resting current is slowly rising....i keep any transmissions short, fer this reason...any ideas of the current increasing?..
..sk..
W7SOE
« Reply #3 on: April 23, 2009, 03:25:14 PM »
Hmm, kinda sounds like a cap going bad.  Have you replaced all the paper caps?
At first glance you might want to check C8, bypass cap connected to the 807 grids......
Rich
W1AEX
Un-smug-a-licious
Apache Labs SDR
« Reply #4 on: April 23, 2009, 03:26:02 PM »
How good is the 6AQ5 clamp tube? If it's weak, that will cause the screen voltage to wander under load. That would be my best guess. Check the components around that little voltage divider at the ouput of the 6AL5 bias rectifier too.
Rob W1AEX
Page created in 0.044 seconds with 15 queries.
