December 02, 2025, 12:18:26 AM *
Author Topic: Selecting replacement caps  (Read 7886 times)
wx3k
Vintage Ham Gear Enthusiast
« on: November 22, 2008, 11:14:28 AM »
I need to recap a receiver I have. It has a electrolytic can, 30/10/10 450v.......Of course finding an exact replacement is impossible. I was thinking of ordering a standard 3 section that is 30/30/30 at 525v.....Would this be a close choice ? Or would a 20/20/20 be better with a 10 uf cap paralleling one 20uf section be a better choice ?
Stephanie WX3K
Eico 720/722/730  HRO50T
"Thunder is good; Thunder is impressive but it is lightning that does the work" ...Mark Twain
wx3k
« Reply #1 on: November 22, 2008, 02:38:30 PM »
 Huh No answers yet ? Is this an embarrassing question ?  Embarrassed
Stephanie WX3K
« Reply #2 on: November 22, 2008, 02:50:08 PM »
I have used higher value (MF) caps in  filter applications with no ill effects...That 30/30/30/ at 525 volts would be my choice...good luck .....Steve
WB2YGF
« Reply #3 on: November 22, 2008, 08:24:20 PM »
How 'bout 20/10/10/10 µF @ 450 VDC and paralleling a 20 & a 10?
CAPACITOR, ELECTROLYTIC, 20/10/10/10 µF @ 450 VDC
http://www.tubesandmore.com/
C-EC20-10-10-10
4 section electrolytic capacitor, used in Dynaco PAM-1 preamplifiers.
1-3/8" diameter x 2" tall
-10% to 50% tolerance
Three 10 µF sections, rated at 450 VDC, and one 20 µF section, also rated 450 VDC.
This is not a standard design of FP cap as the 20 mfd is B(lank). Standard rolling would be D(iamond) as the high cap section.
wx3k
« Reply #4 on: November 22, 2008, 09:47:45 PM »
Good idea  Grin
C-EC20-10-10-10
Stephanie WX3K
« Reply #5 on: November 23, 2008, 08:11:09 AM »
Or you can rebuild the can using discrete components.
Circumcise the can using a moto-tool with a cutoff wheel; the least noticible place is at the base of the crimp.  Pull out the guts, install new caps (hopefully the ones you've bought will fit in the old can), make sure the leads are insulated so they don't short to each other and/or the can, and glue back together with JB Weld.
wx3k
« Reply #6 on: November 23, 2008, 09:25:00 AM »
Cute pic of your pooch ! lol
This is another idea. Is there any toxic chemical considerations when dealing with the innards of a cap ? I think I found a "NEW" can of exact dimensions and value at Antique Electronics Supply.
Stephanie WX3K
WB2YGF
« Reply #7 on: November 24, 2008, 11:07:20 AM »
Just pretend it's 1965 when we didn't worry about that stuff. Smiley
W1EUJ
« Reply #8 on: November 24, 2008, 11:11:22 AM »
Yes - do not take internally. That's all. Now shut yer yap and yank the guts out of that cap!
I use a pipe cutter, it is clean if done right, and the groove it pushes in leaves space for a fillet of JB Weld, hot glue, etc.
ab3al
« Reply #9 on: November 26, 2008, 07:14:11 AM »
dont you dare.... im calling the epa
Page created in 0.047 seconds with 15 queries.
