When you load up the load center with breakers stack them so that the biggest current handlers are closest to the main or have the shortest buss length and are balanced on both sides.
I had a situation years ago in my wifes condo where some big breakers were below some of the lighter breakers. Under heavy current demand weird things began to happen with various stuff in the house. I happened to have a blank in the panel that was open and could see a buss bar glowing a dull red between the offending circuit and main. The load center had the good ole smell of heat emanating from it. Not a pleasant situation to say the least. A simple rearrangement of the breakers to balance out the busses fixed the problem.
EXCELLENT suggestion.
Theoretically, with perfect load balance, the current and and hence any voltage drop in the neutral conductor would be zero.
It's not a bad idea to put some Penetrox, Noalox or Cramolin on the contact fingers of circuit breakers, too. Penetrox and Noalox contain Zinc particles, which act as sacrificial material preventing corrosion in AL-AL and AL-CU electrical connections. They also bite through aluminum oxide.
-Bill
