December 06, 2025, 09:56:33 AM *
Author Topic: New phrase in posts  (Read 207871 times)
« on: May 04, 2008, 07:26:08 PM »
I just noticed that at the bottom of each post there is a link called "report to moderator".  What is the purpose of this?  In case the post is incorrect or improper, it should be used to report the poster.
« Reply #1 on: August 22, 2008, 10:51:02 PM »
I guess it's in case someone joins and posts spam or porn (except for radio porn). Such a person would have no interest in self-policing.
Carl WA1KPD
« Reply #2 on: August 23, 2008, 12:49:20 AM »
If you click on it you get a  message box to fill out and a note that says:
"Use this function to inform the moderators and administrators of an abusive or wrongly posted message.
Please note that your email address will be revealed to the moderators if you use this."
The moderators will take it from there as needed
« Reply #3 on: August 23, 2008, 10:05:42 AM »
Of all places that doesn't need it, this is the place.  It could be useful over at another site I can think of.
« Reply #4 on: August 25, 2008, 09:05:34 PM »
Jim:
The function comes with the forum software. It's been there for a long while. It does get used now and again.
« Reply #5 on: April 24, 2011, 08:28:50 PM »
Looks like it went away.
« Reply #6 on: April 24, 2011, 08:35:48 PM »
It's there with the Firefox browser and not there with I.E. browser.
« Reply #7 on: April 25, 2011, 08:59:18 PM »
I don't see it with either Firefox 3.6.13 or IE 8.0.6001.xxx unless I'm missing it somehow. No matter I usually do not see posts 'bad' enough to have to report. Is it called from another server? e.g. I only see 1&1's ad, no others. Don't see it in source but that doesn't mean much these days.
« Reply #8 on: April 25, 2011, 10:28:20 PM »
Small blue link at the lower right of every post, Patrick.  I don't know why it would show up in FF and not IE....
« Reply #9 on: April 26, 2011, 01:23:42 AM »
Here's how your post reads and looks in I.E. 8 when you don't log in. "Report to moderator" does not appear.
FCC:  "The record is devoid of a demonstrated nexus between Morse code proficiency and on-the-air conduct."
______________________________________________________________________________________
Here's how your post reads and looks when you log in with I.E. 8, the "Report to moderator" appears. Note, I "zero'd out my IP Address
        Report to moderator    00.00.000.00 (?)
w5omr
« Reply #10 on: April 26, 2011, 07:43:41 PM »
Doesn't show up on Linux and Firefox 3.6.16
W1UJR
« Reply #11 on: April 26, 2011, 07:47:35 PM »
Or Safari
« Reply #12 on: April 26, 2011, 10:24:11 PM »
Doesn't seem to be browser-dependent.  I'm running firefox 3.6.16 and it shows up for me.
« Reply #13 on: April 26, 2011, 10:51:42 PM »
John:
Maybe, for whatever reason, within bowels of forum software and browser code churning, the 'Report to moderator" has now become only visible to administrators and moderators. And, unless I log in, I can't see it either which obviously makes sense. Don't remember the last time I received a "report to moderator" message.
test_user
« Reply #14 on: April 27, 2011, 11:02:18 AM »
You're right.  I don't see it, Pete with this test account.  Lemme see if I can figure out what's up.  I know we've received reports as recently as a month ago.
« Reply #15 on: April 27, 2011, 11:11:19 AM »
It's been purposely disabled in the CP, presumably for a reason.
« Reply #16 on: April 29, 2011, 04:58:21 PM »
That Report to the moderator came back on QSO and Tech area. I just upgraded to Firefox 4.0.1. I don't know if that anything to do with it coming back?
Interestingly, it's not on this page so someone must have a way to tick it on and off at Headquarters.
